1x1_Speed_Craig
Simplify...
- Greeneville
- TN
Progress has been slow, but that's OK. We've been busy with other creative projects. A few updates, though.
First, here's a poser shot of Mira with her new (for Christmas) JCR Offroad rear bumper. BTW, do you see the pink bandana she's holding in the first picture? After the rest of the Christmas morning hoopla was done (before we went out to the garage), Mira dug the bandana out of her room, and said she had to be blindfolded before going outside. She wanted the "full effect" when her bumper was unveiled.
...and with her new Ballistic Fabrication battery holder. The engine compartment is pretty much empty now. Mira & I removed the engine wiring harness, motor mounts (frame side), etc. The paint in the engine compartment is in pretty nice shape, so it should just be a matter of quickly scuffing, degreasing, and painting it in the spring.
The floorpan patch repair (under driver's feet) is going decently well. I'm about half to two-thirds of the way done. Again, here's the floorpan after cut-out (NOTE: I used 3-M Weld-Thru coating on the frame rails and under the patch panel before welding it in):
Floorpan with fitted patch panel (recycled from part of the old hood):
Floorpan patch partially done (welds ground down & sanded).
I have to say that I MUCH prefer welding 1/8"-3/16" steel. Sheet metal is a bit of a pain. Fortunately, we're not on a pressing deadline.
Mira got to work on a few things over her Christmas break, including removal of some engine compartment bits, and also starting on disassembling the dash. We did find an amplifier under the lower dash panel; we'll have to test it to see if it works, and will use it if it does. NOTE: Despite the bird's nest that's still in the radio opening, no actual birds were harmed during the course of our work.
I also had some PM discussion on Pirate with Dave at Ballistic Fabrication about how happy Mira is with her Ballistic Christmas gifts. He was pleased that she liked their stuff, but that was the extent of the discussion. Then, on my doorstep last week arrived a small package from Ballistic - a kid-sized shirt with a pink skull printed on front, and "Ballistic" on the back. Mira doesn't know about it yet, and I'm going to surprise her with it when I see her on Tuesday. So thank you, Ballistic Fabrication, for sponsoring Mira with this. She's diggin' your products so far.
That's all for now. More work to come this afternoon after church (I'm itchy to keep working on it)...
Craig
Craig
