How many "hail Mary"s will it take...
Mira is a little apprehensive about using the MAPP Gas torch...can you tell? :D She's heating the upper shackle bolt to help free it up for removal.
attachment.php
Because I'm a nice dad, and because Mira would have gotten completely bent trying to break the bolt free :sonicjay:, I loosened (slightly) the upper shackle bolt, and then turned Mira loose with the 1/2" ratchet.
attachment.php
I mentioned previously that this Jeep build would be full of teaching moments. This is one of them. Teaching moment = Rusty Jeep bolts are a PITB (pain in the butt). :rotfl: Even after I broke it free, and after Mira added heat, the bolt was still somewhat tough to remove. Note the look on Mira's face. After spouting off a few comments in a seriously annoyed tone, I explained to Mira that this WAS a teaching moment, and this is one of the things that us "Jeep folk" deal with on a regular basis. I then became "Mr. Nice Guy" again and removed the bolt the rest of the way for her.
attachment.php
Shackle removed from the mount.
attachment.php
Here's the upper portion of the HD Offroad Engineering kit in place. It's a tight fit. NOTE: Any high-dollar paint you use on this upper insert portion will be scraped up/off when pressing it in place. Tolerances are tight...nice fit.
attachment.php
Here's the actual multi-position shackle mount bolted in place.
attachment.php
Mira reinstalling the original upper shackle bolt, which now holds the shackle relocation kit in place.
attachment.php
The install is still in-progress, as Mira had to get ready for bed (school night). Also, the stock shackle is a tight fit in the multi-position mount. I'll work on getting it finished up later this week.
Craig
i love this thread. I cant wait to do this sort of build up with my son. gonna have to wait a while since he's only 3.
He does enjoy "helping" me. (I give him a wrench and he sees what the wrench fits)
Thanks Bad Karma. Great pic of your son, as well. Give him a 1/2" or 9/16" wrench...that should keep him busy for quite a while on an old CJ. :D
Craig
First of all, I want to thank Eric at JCR Offroad for getting the JCR XJ Rear Frame Nut Strips out to me quickly. I ordered them around lunchtime last Thursday, and had them on my door step Friday when I got home. Woot, WOOT! I'm in the process of cleaning them up & painting them now.
Tonight's "mini project" was doing some minor paint work related to the rear shackle relocation install, and installing these Dana 30 JKS Mini Skids for the lower control arm brackets. The fit was really nice, and the install very simple. Given all the mangled D30 LCA brackets I have seen, I thought this would be a good idea since Mira plans on wheeling her XJ. :rock:
Craig
attachment.php
attachment.php
Naked LJ (soon to be XJ) Dana 44. :cheers:
LJ Dana 44 mocked up with XJ leaf spring perches and T&T Customs XJ D44 truss.
Another shot of the mocked-up Dana 44.
Mira's completed Dana 44 differential cover. I used Eastwood Extreme Chassis Black for the cover, then painted the skull with Duplicolor wheel paint (metallic silver). As Mira would say, "Skulls rule."
Small progress, but progress nevertheless. I got the brake backing plates/outers/yoke prepped & painted, and got the H.D. spring perches positioned & welded on. My Millermatic 135 worked very nicely with the spring perches. :cheers:
Next...shock mounts, and then the T&T Truss.
Once the axle itself is done, we'll paint the brake calipers & detail areas on the rotors with Eastwood caliper paint (but that can be done in the warmth of the house).
Craig
Hi Craig,
Things are looking good. Quick question, why the narrowed 70U in the LJ? Didn't they make XJ D44 early on with a certain package you could have swapped into Mira's XJ? I know my friend Matt sought one out and found one. Or would that have needed just as much work as it was an older style,(brakes/pearches/ect) to swap over?
Kevin
Hi Craig,
Kevin
Hey Kevin...long time. I needed at least a D60 in the LJ to give insurance for the 37" tires. I wasn't going to spend $$$ on an "incremental" axle build. The price was right, the gearing was right (4.88 with Powr-Lok), and the 70U has a baby-smooth bottom with the clearance of a 60.
You're right about the XJ 44. They made 'em for a few years, and I actually had one for Mira's Jeep. However, the cost to build & regear, combined with the fact that it used drum brakes (I had none of this hardware) made the LJ D44 that much more attractive, especially given the low mileage (53K miles on the vehicle). The XJ spring perch positioning is relatively straightforward - I just took my time measuring and checking the angles.
Tell Georgietta I said "hi", too.
Craig
Let me preface this by saying that it's been a full year since I have bought a parts rig... :rotfl:
I'd like to thank Shane Rugg from Grandville, Michigan for sponsoring Mira by giving us a REALLY great deal on this wrecked 1999 Cherokee. Shane has owned it for about 4 1/2 years, and is a mechanic (vehicle is well-maintained). He drove it until he was t-boned. Save the tears...he has a couple other Jeeps now.
This XJ has only 94K miles, and runs GREAT. It also has a variety of other great parts that we'll be able to use for Mira's project. At this point, I think this will be our new engine donor. Thanks again, Shane. :thumbsup:
Craig
Nice score, Craig. Are you going to use the seats? I'm looking for the lower seat cushion, I need a good driver's side but I can make a passenger side work. Let me know if you're interested in selling...
Thanks Randy. It was a great score. Asking price for the vehicle was $900, but he knocked it down to $325 after reading Mira's build thread. He thought it was very cool.
The seats are very nice, and we may end up using them for Mira's Jeep. I'll keep you in mind if we don't, though.
Craig
Wow... even better!
I have great seats in mine, all except for the driver's lower. And finding those in good shape is next to impossible. I think I can make a passengers lower work...my wife has claimed the XJ as hers, so now she wants it pretty...
Wow... even better!
:rotfl:
BTW, I had planned on looking for some late-model seats of some sort to use (e.g. - Dodge Caliber or something), but these are clean/nice enough that I'll probably just use them as-is. The headliner is also in nice shape, and has the integrated speaker pods. I have yet to find an XJ with a nice headliner prior to this one.
Craig
Holy cow, is this a clean, good-running Jeep. It's clean enough that I'll likely be able to use parts of the floor pan to repair Mira's (with the factory stampings). It also runs like an absolute dream.
It looks like Mira's Jeep will get the "heart & mind" of this '99...all wiring, computer, interior, dash, etc. We also decided to go ahead and keep the AW4 auto for an easy swap over. I sold both AX-15s and the other 4.0L (from our '92 donor vehicle) in less than 12 hours, so that more than recouped the purchase price of the '99 XJ. WOOT!
Craig
Here's the LJ-turned-XJ Dana 44 mocked up under an XJ. I got the (higher-clearance) M.O.R.E. shock mounts tack-welded on, and everything looks great. I'm just waiting for the soft brake line kit so I can weld the mounting tabs on the axle tubes before pulling the axle out, finish-welding, and getting the truss ready to weld on.
It's not Cherokee-related, but Mira had her first big welding lesson today. She has a school project where she had to build a catapult that will fire a marble at least 10 feet (study of potential & kinetic energy). We found an old spring-loaded faux cabinet drawer hinge in one of my parts bins, some 1 1/2" square tubing, some aluminum siding pieces, and a teaspoon measuring cup. Mira did a GREAT job welding.
Here's a shot of me helping Mira with the MIG welder.
Mira solo welding on some scrap steel.
Here's Mira testing her final catapult design - a hand-held unit that can fling a rock about 20-25 feet. Since we bought a "bulk" purchase of weld-on skulls for her Jeep project, she welded one of them on her catapult to add a little "hardcore". She also learned to tape off and spray paint...waiting for the paint to dry now. She learned how to tape off parts, and also did most of the spray painting...good practice for her pending Cherokee work.
I got Mira's front axle & control arms pulled tonight. I have to say that I really, REALLY like work on this clean Jeep. The control arm bolts came out like butt-ahhh. It's not what I'm used to when dealing with when working on old Jeeps. Next on the docket...finish removing the dash & firewall bits, and drop the gas tank (it'll be getting the newer poly tank from the '99 XJ driveline donor).
Craig
I got the remainder of Mira's dash items removed tonight...naked firewall. It'll make doing the rest of the floor pan patches considerably easier, and will allow me to make a template for the firewall holes to compare against that of the '99 XJ (dash/wiring/engine donor).
