Jeeptrix frame
scsbccj8
oregon city
or
i have been looking for a replacement frame for mine and i found one made by a company called jeeptrix but have not been able to find any info on the company other than they arent around anymore. has anyone ever used one? any good, bad, or different things i should know. thanks
You are close enough to TDK that it is a no brainier. Just order one up drive out and pick it up.
Used to be some selection between AFW, Matkins, Place down in Tenn with a double tube frame. But Matkins went out of business, AFW sold the shop to an employee and became TDK, and never heard too much out of the double tube guy.
Those TDK frames are nice and much better than stock. I have one in the garage and have seen several others. Everything will bolt back up, and you can get them Hot Dipped galvanized.
They are a little pricey, but unless you can fab your own, considering your time and effort they are pretty cheep in the end.
http://www.throttledownkustoms.com/framesCJ8.html
Carl
yeah i have dealt with Jeremy at TDK before when i worked at Warn. i was just curious about the jeeptrix frame because if i can get a good enough deal it would be worth it. TDK wants 2k for the one i want.
the guy that owned the company used to be on this board..his name is duffy ladd....i remember he built nice custome dashes too..had a nice red scrambler
True....I believe that his son got quite sick and he sold all of his Jeep stuff to raise some money. His stuff was really cool and looked like quality stuff.
Just a note, he hasn't visited the forum since April of '08. FYI.
If you have the time and skills then cut and build your own. There is a big thread on Pirate4x4 in the hardcore jeep section about building your own frame. It is not that hard, but takes some effort to get it right.
There are a few places that do mandrel bending of 2x4 tube but it requires an expensive machine. Art Morison of the Hot Rods does custom work and can build a set of rails or a whole frame for you but I think that it will be as expensive as TDK.
If you need to cut costs, I seem to remember that TDK will sell rails only. So that leaves you with some work to do.
You got to remember that these guys have to make a living too. $2k sounds like a lot and it is, but this is the base of the Jeep and has to be correct for the suspension and everything to work. It is nice to get a new frame to start everything off with and not have to cut and modify. That will save a lot of time and effort.
With an item like this Shipping is what takes a big bite out of your budget. If you can get to the area and pick it up in person you can save a lot off of the top.
If you can you might think about the aluminum body at the same time. They are only a few hours to the north across the border, and then with a galvanized frame you would have a really long lived Jeep.
I forgot that Duffy was the Jeep Trix guy. I bet that he got his frame from the same people that bend up TDK's tube. Seemed like a bad story at the time. I think that he is in Phoenix now, or that was where he moved to at one time.
If you are planning on out-boarding the front axle the whole creating a frame from scratch is much easier. You can use 2x4x3/16" tube and over lap the tube to create the axle hoops. That will give the dimension about correct, and then you only need to worry about width. It will be like a CJ-5 Frame but the wider width of a wide track in the rear.
Carl
its not the skills that i lack, its the time. i have also thought about stretching a wrangler frame but again it comes down to time at this point. with all the OT i have been working that is the only reason i was thinking of dropping the coin on a TDK frame or similar. i think i can get the Jeeptrix frame for $1500 or maybe even a little less but i want to know how they rate.
I bought a TDK frame. with a couple custom things done at TDK total including shipping was around $2500. shipping was $450. total roughly $3000.
I had custom suspension mounts put on the frame to match my 1 ton drivetrain, shackel reversal and rear bumper put on my frame.. it was all stuff i could do at home, but it was easier just to have it done.
I believe the "stock" TDK frame is about $1800 for a CJ-8.
yeah i was talking to jeremy about doing a frame with TJ suspension mounts. it was about $2500 and i was going to go get it. he is only about 8 hours from me.
So you are looking at that older Jeep Trix frame that has been kicking around? That should be a fine frame a lot depends on how it was stored. But I imagine that if it was not made by AFW that they bought the Tube either from them or the folks that bend it for them.
So if you can get a deal go ahead. Duffy did some quality work back then but has not been around for a while.
Carl
i dont know how long its been kicking around. a buddy of mine down in cali found it and sent me the info.
