If you have the time and skills then cut and build your own. There is a big thread on Pirate4x4 in the hardcore jeep section about building your own frame. It is not that hard, but takes some effort to get it right.
There are a few places that do mandrel bending of 2x4 tube but it requires an expensive machine. Art Morison of the Hot Rods does custom work and can build a set of rails or a whole frame for you but I think that it will be as expensive as TDK.
If you need to cut costs, I seem to remember that TDK will sell rails only. So that leaves you with some work to do.
You got to remember that these guys have to make a living too. $2k sounds like a lot and it is, but this is the base of the Jeep and has to be correct for the suspension and everything to work. It is nice to get a new frame to start everything off with and not have to cut and modify. That will save a lot of time and effort.
With an item like this Shipping is what takes a big bite out of your budget. If you can get to the area and pick it up in person you can save a lot off of the top.
If you can you might think about the aluminum body at the same time. They are only a few hours to the north across the border, and then with a galvanized frame you would have a really long lived Jeep.
I forgot that Duffy was the Jeep Trix guy. I bet that he got his frame from the same people that bend up TDK's tube. Seemed like a bad story at the time. I think that he is in Phoenix now, or that was where he moved to at one time.
If you are planning on out-boarding the front axle the whole creating a frame from scratch is much easier. You can use 2x4x3/16" tube and over lap the tube to create the axle hoops. That will give the dimension about correct, and then you only need to worry about width. It will be like a CJ-5 Frame but the wider width of a wide track in the rear.
Carl
