I need thoughts on finding a vehical for a really tall person
ScramblinScott
Now with college degree!
Kennesaw
ga
OK, so I'm 6'7" tall, and car shopping can be a real pain sometimes. here is my situation:
My commute to work is 50 miles round trip
I'm on a budget of about 8k right now.
My scrambler is a drive it on sunny days kinda thing, it's not a daily driver.
I need a large truck/suv for home depot/dump/landscaping runs. And also for towing the scrambler.
I need something that has a hard top so I can leave my stuff in the car/truc/suv without it disappearing. (scrambler is soft top)
I want a modern fuel injected engine, no more choke cables on my daily driver, no more messing with the carb when I go up to the mountains. Must be reliable enough to drive cross country from Atlanta to Houston Tx. and AC, automatic, and cruise mandatory
I am tired of folding myself up to fit in subcompacts, I spend a lot of money at the chiropractor, so gas prices be darned I'm going to buy something that I fit into comfortably. Because my upper and lower back has been killing me. I spend more at the chiropractor than I would feeding a gas-hog.
I fit into my scrambler pretty good, so by association I should fit into a fuel injected wrangler. My question is this: if you were in my shoes, would you spring for a beat up wrangler for a daily driver and buy a beat up old pickup for tow duty or would you just say to heck with it and buy a newer large truck/suv as a daily driver?
Military cucv's can be had in my area for around 3-4K, they are not pretty but would make a cheap and effective tow mule. I can find cheap jeep wranglers on CL all day long, I can also find ford expeditions for 5k now that gas has gone up, what are your thoughts????
I wouldn't assume that about the wrangler....I'm 6'4" and non-tilt wheel wranglers are 100% unacceptable! The scram fits way better. More constructive reccomendations as a tall guy......
1. Late 80's Land Cruiser
2. Early 90's Land Rover Discovery
3. Mid 90's Subaru Outback - Must be and remain covered in mud
I have a 2007 Expedition and it is comfy for me. I drove it 10 hours each way when I went to buy my scrambler and tow it home. I am only 6'1" so I am short by your standards. I get about 20 mpg on the highway and 15 city with the big v8. Some other owners have complained of back pains. I have only have comfort issues when I have my wallet in my back pocket on long trips.
Good luck on your search. But give the Expy a test.
I'm 6'6" and I drive an LJ but I don't drive anything close to that mileage that often and for that distance I don't think I'd ever consider a TJ. The ride difference between an LJ and TJ is pretty significant for that amount of seat time.
If you could find an LJ for that, you could give it a try, but it seems like you want to get a bigger suv to me.
I like my dads Tahoe, never towed with it though.
For 8k I think you can get a something better than a beater. If you look around you should be able to find a desent truck.
I don't know how anything less than a full size truck is size wise but my 1/2T is comfortable and roomy. It would be hard to give up having a truck for me - I don't use it all the time but when I need it it's nice to have the ability to put the plywood in it or the mulch gravel, greasing jeep parts etc.
I'm 6'1" and I daily drove a TJ for 1.5 hours one way to work and back for a long time.. (gas was cheaper, but it still cost my $35 a day in fuel) Jeep fit me fine. should accomidate your height fine too.
my current daily driver is a 2008 VW Rabbit. fits me fine too and there is still room to move the seat back.
if you consider a car, think of the country where it comes from, if the people are tall in that country youre fine. if you buy a car from an Aisian country, they are usually shorter so their cars reflect that in the design.
I'm 6'2", and um...Heavy at 295#'s...
Personally, I'd got for the Expedition. They Tow great, will hold a fair amount and if you find one WITHOUT a sunroof, has headroom.
I am driving an '09 Escape and just returned from a Florida trip with three adults in the car. It was tight, so I'm thinking that anything like that would be out for someone as tall as you.
If you couold find a Ford Excursion Diesel, now your talking COMFORT, Towing and decent economy.
Another thought would be a GMC Suburban.
I came to the relization years ago, becouse of my size, fuel economy is not going to be realistic.
I did drive a '93 Jeep YJ for years and it was OK, got decent economy with the 2.5L 4cyl and 5spd trans. but as the engine wore, the mileage went down fast.
Lesson: stick with the larger engine that doesn't have to work as hard.
Full size vans are a good choice a well, just a real pain to work on.
tow
if your hauling and towing then i would look for a truck, the fuel mileage has gotten better over the years, with the trucks if you look for a ford diesel the 7.3 power strokes are strong motors, i'd stay away from the 03 and 04 models with the 6.0 in them, think the later models they fixed most of the issues with them, the 6.4 ford diesel is a good motor lots of power but a fuel hog......... the dodge with the cummins in them are decent on fuel and pull like a mule on steriods but early models are extremly loud, the chevy/gmc with the duramax and allison tranny is a good work horse with decent mileage and dependable, however with diesel prices like they are that maybe enough to scare you away from diesel trucks and in some areas it's hard to find diesel when traveling but that could be fixed with an aux. tank, unless your towing large loads then i would look at any thing gas the ford, dodge, gmc and the chevy in a 3/4 ton just check on which engine and axle ratio, to low it's a gas hog, to high and it's a crippled up 3 legged dog with a load that can't get out of it's own way. one other option to a lower gear rig is you can always install a gear venders overdrive where you have a double over drive they are costly at around $3500.00 but they say fuel mileage increases up to 22% which at todays fuel prices it would pay for it's self in a short period.
I'd also say check out the Suburban and Expedition. I'm 6'4", and I love our Suburban. All-around, it does everything. Great for road trips, camping, hardware store runs, hunting (I can tell you that an elk & a deer will fit in the back, even without the second row folded down). On a search & rescue training last summer, I put the thrid row of seats in, and hauled seven above-average-sized guys and all of our gear for a couple hours in total comfort. My father-in-law has an Expedition, and it's just as handy. The Expedition has a little more ground clearance, but a little less room and refinement inside. The downsides (at least for the Suburban) are (1) mileage (not really too bad, but not great), and (2) driving it gets a bit boring at times. But that's what Jeeps and motorcycles are for.
I bought a used 2001 for $12,000 a few years back, and I see 2001s and 2002s around here now for about $8,000. If I were doing it all over again, I'd probably get a 3/4-ton Suburban, as I'm doing more towing with it than I expected. (The regular, 1/2-ton version does okay with towing, but we've got some steep passes around here, and I like to have power to spare...) The pre-2000s had pretty poor braking, so I'd stick with 2001 or newer.
i would seriously consider suburban or a crew cab pickup.
The GM 5.3s are solid but if gas prices are damned and you want something in a 1/2 ton to do a little bit of heavier towing the 6.0 or 6.2 is even better.
Be careful with a couple of the Ford 5.4s though. iirc correctly the last generation of that motor had some valve issues.
I'm not near 6'7" (6' even) but I have an 01 Dodge quad cab 4x4 diesel, it has 240k miles on it and still works fine although I recently replaced an injector pump and had the trans rebuilt (typically 135-150K item) but I've had it with very little issue for about 45K miles, gets about 18-20 mpg on the road, around 15 in town, cruise, ac etc. There is plenty of room for me, I can barely reach the wheel with the seat all the way back. Mine was a utility company truck and had full maintenance records, was VINed as an SLT but has all rubber floor mats and is very basic as a work truck would logically be. I paid <$10k about 5 or so years ago so I would think a comparable truck would be had for your range and I can guarantee it will pull the scrambler and anything you want from HD.
I'm 6'4" and i have plenty of room in my buddys dodge, he's getting around 20 to 22 mpg on the hiway with his single wheel ton truck, ive talked to a few dodge guys that have done the gear venders over drive in their trucks and they swear they are getting anywhere from 26 to 30 mpg with their crew cab duallys unloaded on the hiway, my ton dually crewcab ford gets around 14 to 15 mpg empty not to bad for a box car with 4:10 gears i have considered doing the gear vendors on it if i keep it.
Sinceable daily driver / tow rig is a modern (2000+) 1/2 ton truck, or the suburban/expedition. Any of these in 2wd will get close to 20mpg. I know a newer expedition will beat 20mpg on flat interstate. Towing a scrambler you'll drop to somewhere around 12mpg. You should be able to get a nice one for your budget.
The dodge diesel that gets much over 20mpg is like bigfoot. People swear they've seen it, but I'm not gonna believe it.
