Full Color CJ Wiring Diagram!
Randyzzz
Blown Budget
BENEFACTOR
Gold Member
Redmond
OR
Found this while working on my wiring this morning. It's super high quality. I downloaded it, and printed it through "Paint". Takes about 12 sheets of paper, trim, match edges, tape and you're set. It's for an earlier year I think (79?), but it sure is cool!
https://docs.google.com/leaf?id=0Bx...NmRhZmVmNmE1MDQw&sort=name&layout=list&num=50
I have that, too. I printed it out on 24x36 paper at work, but it is in black & white. Hanging in the garage. Wish we had a large format color printer.
We should have a contest to see whose Scrambler's wiring actually looks the most like that diagram. I'll bet there wouldn't be too many entries.:D
Thanks for sharing. I printed it, spliced it, and carried it to the local office supply store and got it laminated. Came in very handy for my current project which didn't have an under dash wiring harness in it at all.
Welcome to the forum ..........BOBBY !
wiring diagram
Just email it to your local blue print shop and they can print out and color that's what I did
I had the print shop teacher put it on a large sheet of vinyl for me before we moved.
I printed one on a color plan printer and then laminated it with an over sized lamination machine. I think it is 30" x 42" as I recall (standard architectural plan sheet size).
Not quite 30x42. More like 36x17.
Or anyone has one for an 84 Right-hand drive?
RHD is essentially the same as LHD the only differences being mainly with the lights and the addition of the extra parking brake dash lamp and the extra lamp for the auto shifter as i guess you have a postal?.
If you need any specific help just give me a shout, just going through all mine now on my rebuild.
My AK Postal is in the shop because it will not start. The people working on it think it is an electrical component but are not sure where hence a wiring diagram. The ignition will turn without a key, but for some reason, when trying to start the engine, they say that the polarity is switched and the engine will crank but not start because it does not have the correct electrical signal. This happened over an AK winter of sitting and some battery issues. They have already tried switching the leads. Any assistance is greatly appreciated!
