Scrambler on a budget
When I was a kid. I put a REVEL MOPAR together a 1970 HEMI CUDA and painted SUBLIME GREEN.
That was a factory color back then. So I promised myself if I got around to building a HOT ROD that was going to be the color. It took 30 years to get around to doing a build to use the color on a full scale.
I love the color and green is not seen on cars or trucks much.
It might have helped that the primer I used was tinted green also. So when the paint went down it covered realy well.
Keep up the build have fun doing it.
great story i like that color 2. i went with the sassy grass and black primer to make it a deeper green, it also changes under florescent lighting. cruse nights :evil::evil:
i just put 2 coats of semi-gloss to the firewall, it looks ok. when the engine gets swapped i can do a better job
frame needed painting due to the overspray, so now its back to shiny again
next the dash needs some green.
i wasnt looking forward to this job but it wasnt that bad. when it goes together i can fix all the gremlins, grounds and lights issues.
Thanks for the pics of your dash. Now I now how my dash is supose to look.......
You might not have a lot of replies, but you have 7800+ views, you're helping lots of people :thumbsup:
Keep up the great work!
Now that both of our scramblers are awsom green well its a given that I check your build out,
WRENCH ON
paint prep just plain sucks :angry:
once i get it in the light im sure there are lots of spots to touch up, but it looks way better now.
ARB locker looks good hard to believe i have them.
FINALLY!!! got to put on my Xmas presents from the kids. i'm pumped :woot:
Solid
Steering brace is on.
the only thing left is tie rod flip. i just need to find someone with a taper reamer
Everything looks great , I feel the same about my ARB's
From the looks of this pic
Don't you think you should have a drop pitman arm?
If you decide you do , I have an extra one that I will make you a deal on !!
i was going to do that but the flip makes more sense to me. it does the same as the drop pitman and moves the tie rod and steering rod up an inch or two
Ok , I missed that you were going to do that
So, I have both, do you ( or anyone else) think that mine is too flat
Do I need to go back to a stock pitman-arm???
Don't think you "need" to, but you certainly don't look to need the drop one and it's hurting your turning radius.
Yes, sorry, forgot the quote button and yes, I'd have the stock arm on there. The D44 I have is "flipped" by design/stock and I run the stock pitman. People do flips so they don't need to do drop pitmans.
Ok , thanks for the help, now I need to find one
Of those tools to open up the stock arm
the grill and dash are painted :cheers::cheers:
today the grill got installed and sunday the dash.
next i installed my sway bar and the repainted shocks.
a friend of mine is loaning me his taper reamer and i'll do a tie rod flip.
