7jeeps7kings
- right near the lake
- OH
I'm already VERY familiar with the AMC cam/distributor gear issues, and I have the internal valley oil-line for the rear-main. The oiling issue with the cam gear is relatively minor, and if you've got "the problem" more oil won't fix it. When I first built the 401 I spent a LOT of time on the AMC Forum learning from the drag-racing guys how to build a 401. The oiling issue is due to flashing left on a slot in the timing gear; if you file out the flashing you'll solve that minor issue. The external oil line is a waste of time; the AMC forum had a guy that kept going through gears so he added the external line, only to pull out oil-soaked and very broken cam gears.
The issue is cam walk. When I first did the 401, my builder machined a Delron cam-button for me, and I went with a bronze distributor gear in addition to a new Crown timing-chain cover. That got me home and the engine seemed fine, until I had a lifter die on my Summit cam. So when the new cam went in, 90+ miles later, it ate the distributor gear.
I mostly order parts from Randy Guynn at Performance American Style. I called him up for advice, and he said that when Crown first started making the replacement covers, about 50% of them had incorrect specs for the positioning of the distributor. He discussed the issue with Crown and they tightened up their tolerance, and he said he's seen no others come through with the same problems. He said it's possible that I got a bad one (I think I ordered it through 4WDH), and he recommended replacing it.
He also said that the sacraficial distributor gear, while it might save bearings, isn't a long-term solution, and told me about just getting the matched new set of hardened gears each time this happens. He's also heard of guys going through two or three sets of gears before a fresh set finally breaks-in together.
So I ordered a new cam gear and distributor gear, and a new timing chain cover. I ran that for another 90 miles and had another lifter fail. After two lifter bits and a distributor gear went through the engine, I thought it would be worth pulling the rear main cap to look at the bearing. Bad.
So the 401 had a rebuild with a new cam. That set-up lasted for several years, and then suddenly a cam gear went out. 90 miles later, it went out again. This time I added a thrust-plate that sits underneath a specially-machined timing gear to go along with my cam-buttom. 95 miles later, I was sitting on the side of the highway at 9:20 yesterday morning.
I think this time I'm going to tear out the cam and stab a new one in there, in addition to checking out the bottom-end (again) and the journals on the cam. I'm thinking that maybe the lifters have worn with the cam in the wrong spot, and there's only so much anti-thrusting that will keep the cam from walking.
In the meantime, I'm going to evaluate my options for the California fiance & top trip.
Sorry to hear about your bad luck with your 401. I have had very simular problems with my amc 360. I did not make it to the part of having the cam button made. but it was a thought I did have. but I have blown the front end parts out my amc v8 mutliple times in my cj7. And have gone through multiple covers, gears, cams... stay away from summits cam. I smoked two of them. and finally bought a crane cam. The crane cam is working good. this last set of matching gears, timing chain cover, oil pump, and cam have lasted almost 5 years now. I think after I get done with my wifes cj8... I'll problem end up doing a 5.3l swap into the cj7. Thats if I like the 5.3L engine in her jeep?
also if you didn't already know try this website they have great parts:
http://www.bulltear.com/
its tuff running these amc v8 engines. i have a 401 on a engine stand that was going to go into the wifes cj8. but then I remembered I hate fixing stuff. LOL good luck
