Scrambler on a budget
a little advise needed
what i need to do is seal the rocker knockers and the crushers to the body/paint so no moisture gets between them ,and the rot starts all over again . :banghead:
what have you all seen/ used to do this ??????
I've actually read that doing that can lead to more problems.
Automotive seam sealer would be my guess. I didn't bother, but that's really because I was just hiding the rust that was already there :eek: I'm afraid to look now...
FINALLY!!!! all my parts are painted and in my possession :smokin:
7 MONTHS!!! i had to deal with the biggest pain in the ***. i cant tell you all what i had to endure because he had my cash and parts, i couldnt change shops, it was a NIGHTMARE!!!:banghead::banghead:
plus he gouged me on price. im sure it will come back to him somehow with all his bad karma .
my xmas gift is i never have to speak to him again.
here are my doors i just have to wait for an extra set of hands to help me install them.
today i assembled both full doors and 1 half door .
im still waiting for the weatherstrips, those little plastic retainers and some 1/2 door pieces.
the pia was the door handles with those 2 slides :angry:
i decided not to install the thin aluminum trim covers. i thought it looked way better this way.
painted the door panels black.
when its warmer out i can do all the bolt touch ups, seems every one has chunks missing.
Yo Demon....where did you get all your seals and everything. I'm at the same exact stage as you.
christmas ride
it was a good day to christen the jeep in a little mud. so i took my big present out with the kids.
what better way to spend the day...?!
looks great... are you going to get some fender flares? I think it'll really enhance/finish off your blacked-out look.
i picked up some new to me stuff. all this for $40 from a very nice fellow jeeper.
the KC 6in lights look like sealed beam variety. i never saw this type before, but they work great :cheers:
the alternator i used as a donor for my 65amp. the brushes were good and the regulator was also good, so now i dont have to buy a new one for a long time. now 13.8vdc with everything running at once.
the KC rectangle's are stainless so im replacing the pair of rock lights i have now with them.
the air cleaner will fit on my mc2100 when i find cash to do that.
Holy crap what a haul for $40!!! Those old KCs are incandescent lights, if one goes out you replace the entire light (minus housing) rather than just a small halogen bulb. But yes w/ good proper wiring they should rival new fangled halogens.
+1 on fender flares.
your right they are super bright, makes the main lights look yellow :drool:
my steering sucks; bumps throw it everywhere, and is scary with a load in back
i ordered some 5 deg. shims to correct my castor. i read 0deg on my angle finder on top of the ball joint nut. i got them from tom woods in UT . they charge $25 and $5 processing.
http://www.4xshaft.com/index.html
!!!if your going to do this make sure to get solid steel shims, NOT cast iron or aluminum from what i've researched .
good reading here:
http://www.jeepforum.com/forum/f8/why-your-steering-wanders-seems-loose-445430/
next week i give all of you an update
weird but i cant seem to post without some pix :D,
i needed to get the small stuff done because this jeep just became my daily driver.
my old benz gave up her trans and i have to save up for a rebuilt one.
1 dana 300 output seal
1 new wiper arm
1 new headlight surround
4 axle u-bolts
KC soft covers
tom woods solid steel shims to correct my castor
$30 delivered
i was at 0deg so i ordered 5deg shims
all 4 of my jackstands are being used on the benz so i had to improvise using my only jack.
i used a c-clamp to hold the spring pack together. it was a cake job.
the shims are made for yj springs so i needed to grind them a little.
went for a short ride after and what a big difference.
it tracks straight and returns to center after a corner.
all it need now is an alignment.
and...................LOL
important note::banghead::banghead::banghead:
i ordered a u-bolt kit for a dana 30 from quadratec thinking 1 of them was larger to go over the pumpkin. Wrong all same size. i had to use an old u-bolt off my sons xj as a temp fix, im calling them today to see why.
Sorry to hear about the Benz but there is no better way to truly get to know your Jeep then by driving it every day. You get very familiar with every bump, squeek, vibration, and know what it should sound like and when something isn't right. I plan on driving my Scramber daily for about 6 months once I get it finished.
Don't I know it.
Nice job by the way.
wow it been a while since i posted!!
love this jeep even though it sucks down gas and tops out at about 55 - 60 mph with its gearing.
35 inch tires would help and or a 5 speed tranny. maybe BOTH :woot:
i've put about 1-1.5k miles on it since the paint job was finished and no issues its been great.
i bought this seat last year and decided to put it in today. i chose this way for legroom and its great for drive-in movies
