Scrambler on a budget
i was still having some typical cj leaning issues, still to the drivers side and i had already switched the rear springs. now it was time to switch the front ones. i also needed to replace the bushings. i had them in my toolbox for a year .
after this was done it was hardly leaning, and it seems to ride better.
1/2 door weather
the weather is great here and i cant wait anymore for the 1/2 doors.
i assembled them
aligned them
then enjoyed them :D:D:D
next is getting the bikini top on after i figure a way to get the 1/2 top off by myself. my son is back at college :shrug:
so hows everyone doing with their jeeps????? kinda quiet in here lately. :ZZZ:
i rigged up a block and tackle, strapped on a couple of tie downs and got the top off myself.
got the bikini top on and thought back on when i first purchased my cj.
this is what i have been waiting/working for.
sassy grass green, 1/2 doors ,bikini top, trail ready and a beautiful day to enjoy it all:D:
my steering wheel has been crooked since day 1 and i thought it was time to align it.
$75 to set the toe at the local shops, $180 for a lifetime alignment decisions decisions.
to hell with them, i did it all myself so far, why not the toe adj.
you-tube to the rescue here are the 3 vids i used.
http://www.youtube.com/watch?v=W8qFjAB67vk&feature=endscreen&NR=1
http://www.youtube.com/watch?v=gjcP07VKVZM&feature=related
http://www.youtube.com/watch?v=RpEwSeSJVW4&feature=fvwrel
picked up some broken tiles from home depot for FREE!
sprinkled salt between them so they move freely
set up 4 jack stands with twine set parallel to the rims on both sides
then measure and adjust the tierod so that the rim is parallel on both sides
i had to remove the tie rod and unscrew it 2 turns to get it right.
once both sides are set i set the wheel and then adjusted that tierod to fit in to the knuckle.
went for a drive and it goes straight down the road with a centered wheel.
now its time to put as many miles on it as i can; that is if i can afford the gas.
:thumbsup: Very nice! Slick way to set the toe in too!
Big +1 on that, very clever! I've pondered the same notion in the past, apparently people have made it a reality. I should have patented that thought, I'd be driving a fleet of FINISHED Scramblers by now. :D Anyways, awesome, awesome, awesome. Very nice Scrambler, very well done.
I've also pondered the same notion on self top removal. I'd like to see a pic or two of your block and tackle. I figured pick up a cheapy since strap or two (not even ratchet straps, just the ones you pull down tight by hand) and fab up some rigging from the ceiling joists. So pretty much what you did. :cheers:
Cool part about using some type of straps for the actual attachment to the top (at least the front one) is being able to adjust it to balance the top nicely. :thumbsup:
thanks guys :)
top removal was 1 motorcycle strap with a hook on both ends and the other was just 1 inch webbing strap with a friction clamp. you can see it in the photo.
the block was something i had made up for my canoe years ago, before i stored it outside.
basically two pulleys together at the top on rafter and then a single pulley attached to the straps with a small d-ring.
the top is light but bulky ; and i wouldn't want to store it in the air on this setup for the winter.
i put it under a tarp out back so less chance of damage.
I got a hoist for my old LJ fulltop and I was wary of storing the top from it by itself all summer, so what I did was use the hoist to get it up in the air, then I put eyebolts into the rafters roughly above the three hooks on the hoist arms and used chain with threaded quick links between the hooks and eyebolts to actually take the weight off the hoist frame/cable (but left the cable just taught and not tight).
This way I just had to pop the three chains loose and I could lower it down when needed and I had a redundant storage method for hanging it up out of the way. Worked great!
Awesome job man! Looks great:thumbsup: I'm hoping to start on mine when cold weather comes back.
I just took the top off for the first time in 28 yrs. My dad would never let us, said it made it leak. I went and knocked on my neighbors door to help me lift it off, lol.
Anybody know a good place to get the seal for the bottom of the bulkhead?
this is what i used on my top, its been great no leaks. double or triple up on the camper seal tape. sticky side on the top :D:D as for the bulkhead, i didnt seal it but the camper tape should work fine.
my dana 300 has always been a little whiney, nothing real loud. it just lets me know its there on excel, mostly above 30mph and in 4th gear.
no noise on coast and just a little whine on the flats without much throttle.
is this normal?
when is it time to crack it open and put a rebuild kit in it?
is this normal?
My green '83 Scrambler, which has 126,000 miles on the original power train, is silent. My rebuilt red Scrambler's Dana 300 is also silent. I would tend to believe they should NOT be noisy:shrug:
Check the oil level first. If it has oil and is making noise, hopefully it is just a bearing. Rebuild kits are fairly inexpensive, and if you have access to a press, you can rebuild it yourself for around $150.00:cheers:
I had bad drivetrain noise for awhile, varied based on whether it was under load or not....
before you go crazy on it, recommend that you elevate the vehicle and put it in drive.. you might find (like I did) that you have a bad pinon bearing in the rear end, and (under load), the drivetrain is transferring noise UP the drivetrain into the transmission tunnel, deceiving you on where it's coming from... worth a few minutes to isolate the problem (if you haven't already done so)
thanks never thought of that, i guess i could even remove rear shaft and try FWD to see how it sounds. :)
hey does anyone know where i can get a roll bar that bolts to the dash by the top door hinges and has a type of collar that attaches to the factory roll bar in back?????????
i saw this set-up on an 8 just recently.
whats cool with it is no welding and i could remove it in winter to put the 1/2 top back on.
Rockhard sells a bolt-in cage kit that attaches to the dash, no welding, like you're describing. It has it's own bar in the back and doesn't use the factory bar. The half cab fits on with this cage in place.
I have this in mine.
thanks do you have any pix of it ?
after i read your post i checked out their wed site and liked what i saw on it.
this saturday OK4WD had their annual open house and i met the owner of rockhard. nicest guy to hang with, so i bought one with free shipping and 10% off.
now i'll have some rollover protection, grab handles and a mount for my 3pt seatbelts.
now after i see yours i know i made the right choice. looks GOOD!!
thanks john n for the info.
