Just bought my 1st Scrambler
regular guy
Cameron
NC
1983 with a 4.3L Vortec, T-5, Dana 300, 4.56 gears with ARB Air Locker. Dana 35 up front and 44 in the rear, 255-85-r16's. Came with half hardtop and bulkhead, full Kayline softop, full hard doors and half soft doors. Paint is original as are all the decals. On to the pictures.
Apparently the engine swap was done by an engineer. There are a bunch neat little things on this jeep which smack of someone pretty freakin smart who thought it out. These include:
Air Tank for the ARB's is the front bumper.
Vehicle wired as a tow vehicle. Switch on the dash for run/tow turns lighting system into a trailer wiring system.
front AND REAR warn hubs. Just leave the rear in 4x4 when you drive and flip them to 4x2 when you tow. All axles disengaged.
Wiring harness was spliced wire by wire to integrate the 1994 4.3L to the 1983 Body. There's a check engine light and an OBD2 sensor under the dash.
First thing of many I did was replace the tailgate cables, swap over to the full soft top(thank you Walkerhound for the walkthrough of the early kayline install. I was staring at pieces until I found your instructions) And put the rear seat that came with it in so its more family friendly.
Anything you can think of good or bad that I didn't mention would be greatly appreciated!
My wife helped me out by trying the vent window out while we were driving down the road. The bottom pin was rusted and it fell out while driving 50
Congrats on the purchase and welcome to the club! The full float rear axle is a nice upgrade! A little wash and wax on that paint and I think it will look great with a very nice patina!
That looks great! Those upgrades sound awesome, How does it run?
Like a car. Fires the first time. Steering is super tight, only about an inch of play in the steering wheel, compared to every other cj I've owned where a half turn of the steering wheel to get a response. It goes down the road at 65 at about 2200 rpm.
Nope. Guy I bought off of was a sheetmetal fabricator for 15 years. He said it's gotta be close to 30 gallons. He never filled it all the way up. It goes from right behind the rear axle to the bumper. I'm going to fill it up tomorrow and see what the capacity is.
tanks...tanks a lot!
Should be between 30 and 33 Gal. I got this one before I cam to Germany but never got to install it so its sitting in storage.
Sorry... can't locate a pic. It basically looks similar to yours, occupies the factory area and straddles the rear cross member to fill the empty area in back.
That's a fantastic looking Scrambler. I LOVE patina like that. I wouldn't do anything other than rust treatment :drool:
So, if I wanted to keep the patina, how would I go about removing the surface rust without removing paint? What kind of prep would prep the metal and not affect the remainder of the paint?
Went junk yarding this morning and found the set of rear seat brackets for the fold and tumble seat I was looking for. I also found one almost perfectly good half door and one that was missing the interior panel and the mirror. I'm thinking about going back in the morning and offering $150 for both. There was a third half door that had been a part of the accident, but I'm thinking the internals might still be good. The interior door latch was.
I really want a pair of half doors! I think they go with the lines on a jeep better than anything else and even more badass on a scrambler. Pairs are going for 350-400 on craigslist out here. I'm debating which would make more sense. Paying more for a pair that are good from the get go or get some cheap ones and repair them.
That is a nicely done spring over axle swap as well. The CJ sits very low. I would bet the ride quality is fantastic.
The ride is awesome! It doesn't drive like any other jeep I've owned.
In the past couple days I've gotten the oil changed; L rear Taillight, R front marker light and R rear backup light replaced; Air filter replaced, fuel filter replaced, Rear seat changed out for a fold and tumble (the old one went into my buddy's 60's cj5); pulled the cassette deck; and got the softop on. I also got the clutch adjusted and it hasn't slipped since so I think I've got that one nailed down.
Here are the issues I've run into so far: Bottom fitting on the radiator has a slow leak, fluid seeping from the back of the transfer case, fluid seeping from the clutch housing, and a weird electrical issue where I turn the key and it won't start.
The electrical issue is throwing me for a loop because the electrical system says that the starter is drawing power (all gauges drop to zero) but no sound what so ever. I let it sit, come back a couple hours later and it starts right up. Any electrical guru's out there got any ideas? It was happening before the stereo was pulled. I taped up a bunch of loose wires under the dash in case it was a short and taped off and labeled all the wires from the stereo, but it happened again last night. Any help would be greatly appreciated. I've been holding off on pulling the dash, but that is going to be my next step. Pull out the engine TSM and the Jeep TSM and start figuring out where everything goes.
Evapo-rust.
You can pick it up at Harbor Freight (if you have one nearby) or AutoZone I think carries it.
I've used it quite a bit and have been real impressed. I've used it on a butter tub full of factory 8 fasteners with paint on them and it didn't seem to effect the paint at all. However, if you leave it on there long enough to where it dries before rinsing it off, it leaves a residue and could probably stain or discolor the paint especially as "dry" as your paint looks (no longer any clear coat or shine to it). Get a small bottle and test it out some and see what you think. I really like it.
So I've been fighting an electrical gremlin for the past week and he's been kicking my butt! I drive it with no issues. I go into a store and come out, turn the key, one click, and then the whole battery system is dead. I did some troubleshooting and there was an inline fuse coming from the positive battery terminal. I pulled it out, waited a few minutes, put it back in and my battery was still at 12.6v. More idiocy from me before I figured out that the negative connection was loose. I tightened it. Looked at some more stuff, drove it the next day and it did it again. Played with it some more, More idiocy by me in not catching that the positive terminal was also not getting a good connection. Side terminal posts screwed into a connector for top terminals is NOT a good match. Lead doesn't thread well. So I pull both top terminals and connect to the side terminals already on the battery (Optima Redtop made in Mexico: Still going strong so far) and it's good to go.
In the process of troubleshooting, took a look at the starter and there was a chunk missing from the bakelite on the end of the solenoid. So I go to replace it. It crumbles upon disconnect and I go to put in the replacement starter I picked up the night before from Autozone.
Now it gets interesting. My scrambler has a 1994 4.3l Vortec. I get a Duralast Gold starter for a 1994 Chevy s10 (what the engine came out of.) It DOESN'T FIT! Offset mounting holes rather than inline like mine. Lots of frustration and back and forth with the TSM and proving that it is out of a 94 and it is a 4.3l. Fourth trip to Autozone I tell them that I am going to NAPA for the starter because NAPA's is inline. The old crusty guy the works at Autozone stops using the damned computer to looks up parts, goes in the back, goes through 4 starters and comes out with one exactly like my broken one. Part number didn't match, but it was the same one. 15 minutes after getting home, I fired it up and it started no problem. Now to see if it will keep it up. Too much damn wiring with the newer engine!
Autozone was great and worked with me, but it was kind of funny after I was done being frustrated that the old guy who didn't use the computer figured it out.
Sorry for no pics, I was in a time crunch to get it done.
Another fun fact! I have a 4wheelparts store in the area. Bought a smittybuilt center console (no cupholders sucks!) i go to install it and it was a return they put back on the floor! Missing parts and small parts in a ziploc bag. I'm going to return it tomorrow. Kind of weird! First time I've shopped there in about five years, but not a good first impression!
Nice 8. Would you call it a "Renegambler" or a "Scramblade"? Watch out, it looks like she's got a split personality.
Well, I'm down to two leaks in the engine compartment. I replaced the old crappy coolant reservoir which had a hole in the lid and sloshed coolant at every bump to a brand new one in the original position under the master cylinder. Still leaking from the weep(sp?) hole in the brake booster and the passenger side coolant line on the bottom of the radiator. New master cylinder and booster are enroute. I am going to end up draining and replacing the engine coolant and replacing the line to fix coolant leak.
Also got a great score off Craigslist. T4 transmission out of a cj7 with 67k for $125. It appears to be in good shape. Came with a bellhousing as well. Anyone suggest the best Transmission Overhaul kit? the prices for them seem to be all over the place. The plan is to figure out how to rebuild the T4, swap it for the T5 in it, rebuild the T5 and swap it back in, and then sell the T4. Kind of have to do it this way as this is a daily driver. Also picking up a professionally rebuilt Dana 300 to swap out when I put the T5 back in.
Fun fun! I remember now why I love Jeeps so much, Legos!
Crappy old reservoir from i don't even know what. Notice hole in the lid
New tank mounted. Filler location sucks, but I am going to fix the lines when I replace the master cylinder
Leaking line on the bottom of the radiator
Leaking weap hole
