Best < $100 Mod / upgrade
tower210
Olathe
KS
Just installed a hoodlift that I received for my birthday. LOVE IT! No more flipped hood and towel.
What's your favorite inexpensive upgrade?
Emergency brake:
Each of these was under $100 for me and each had a notable difference/improvement:
Headlight relay mod
Used MC2100 install
Used HEI install
Used bumpers
LED interior lights
Used aluminum valve cover
Wagoneer horn swap
Ok. What is the headlight relay mod? Gives brighter headlight action? And is the wagoneer horn louder? Mine is a bit anemic.
The stock setup sends all power for the headlights through the switch in the dash, you can imagine how inefficient (and possibly dangerous) that can be in a 25+ year old vehicle/wiring. There's a couple of writeups on here, (if you find one, post the link here and I'll turn it into a tech article.) It's just putting a relay in for each of the high and low beams with an inline circuit breaker for each so power is coming straight off the battery.
The Waggy horn is a dual note horn setup that sounds much better.
For me, the best under $100 upgrade was flipping the tie rods. I bought the tie rod inserts from Goferit and drilled the steering arms out myself, tacked the inserts to the arms and moved the tie rod up above the leaf springs out of harms way. The other equally cool thing about doing this was that I was able to ditch that awful dropped pitman arm and use the stock arm, which, by itself doesn't sound like much, but the turning radius was significantly DECREASED in the process.:woohoo: That means I could steer around tight corners on trails and park in a regular parking lot without having to back up at least once to do it. Most bang for the buck mod I have done to date.
Ah. Thanks Eric. I will look the relay posts up. Sounds like a great easy mod.
MC2100 is in my garage waiting for a day off. I'm very hopeful for that one. I've only put about a thousand miles on since June, but a couple rounds of quick dirty math are hitting 10 or so mpg on my rough carter.
Excellent one! I did that with my stock axle when I did my first lift and avoided the dreaded drop pitman (which was a part of the RE kit and I sold it off to recoup a little $$). I also ended up using one of those bushings to make the Waggy steering setup work on the Postal (taper in the DL went the wrong way when switched around for my RHD). I know Sheldon that runs Goferit, very good and helpful guy.
Best budget swaps i can think of...
E-Code Headlights. Uses H4 bulbs. 55w low beam 100w high beam.
Hella super tone horns (same horns that desert racers use on their buggies)
Also had a air horn off if a fire truck on my CJ7. Have yet to put it in the 8.
I cant remember if it was under $100 but i put a rear view mirror out of a 2004 TJ... Has map lights, compass and thermometer...
Sent from my Illudium Q-36 Explosive Space Modulator
Direct ground to frame for the gas tank sending unit. Nothing better than a gas gauge that works. That one was probably less than $1.
And well worth it!!!! Running out of gas due to a bad gauge stinks. I know the pain.
I added these marine grade string lights all the way around the bed and wired them up to the interior lights. They are tucked under the lip of the bed. I also added this cool rear view mirror that came out of a GM pickup (I think) and wired it to the interior light switch also. It's great for mood lighting, or to find your keys .....
