Sanity Check
Today I received the CRT HEI distributor. Great looking unit with detailed instructions.
Now for a little sanity check. The instructions state to rotate the engine via the crankshaft bolt to 0 deg TDC. Which I did.
The instructions say that the rotor should be pointing to the #1 terminal on the cap with the engine in this position. If not then you should continue rotating the engine until it is...here is their verbage: "STEP
4: Put the appropriately sized socket wrench on the center bolt of your engine’s lower crankshaft pulley. By turning the socket wrench clockwise, bring the timing mark on your crankshaft pulley all the way around until it is lined up perfectly with the TDC mark on the front of your engine.
STEP 5: Lift off your distributor cap and note the position of the rotor. It should be pointing directly at the #1 position on the cap which you previously marked. If it is NOT, then secure the distributor cap and repeat steps #4 and #5."
When I took the cap off the distributor, this is where the rotor was pointing.
As you can see, it wasn't pointing at the #1 terminal on the cap, more like #2 or 4. Now I am unsure if that is because the Howell EFI that was on the engine required it to be timed at 8 deg before TDC. Either way, per the instructions I just verified that the engine was indeed at 0 deg TDC for the installation of the HEI Distributor.
Here are the next 2 steps:
"STEP 8: With a flashlight, look down into the hole of the engine where the distributor fits. You will see a “slotted” shaft. Now, holding the distributor with the vacuum advance pointing at the passenger’s side of the Jeep, position the rotor so that the distributor shaft will fit into the “slot” down inside the engine. You will have to turn the rotor counterclockwise a little so that when you set the distributor into the engine, it will turn clockwise as the distributor drive gear seats into place. (Turn the rotor back approximately the amount that the gear turned as you pulled it out in STEP #7) The distributor should sit ALL THE WAY DOWN and rest nicely on the engine block. If it doesn’t, pull it out and try again until it does. Note: You may have to slightly bend your oil dipstick tube out of the way of your new distributor since the cap is much larger than your old distributor. Be very careful not to break the oil dipstick tube.
STEP 9: Place your new distributor cap back on the distributor. (make sure it’s on STRAIGHT and the NOTCH is aligned properly with distributor housing! It can be tough going on the first time, as the plastic caps tend to warp out of round) Note which spark plug wire terminal the rotor is pointing closest to. Tighten down the distributor hold down clamp and mark the spark plug terminal on the distributor cap #1. Secure the cap to the distributor."
I aligned the distributor shaft with the orientation of the oil pump shaft, easy. Dropped it in to the same orientation as the old distributor. The instructions say to then note which spark plug terminal the rotor is pointing closest to and this is the new #1 terminal. So from what I saw, the new #1 would be the terminal at the 3 oclock in this picture. The one right above the label on the right side of the cap.
Could anyone who has experience with this install please confirm that I am in the ball park. My concern is that the rotor of the old dizzy was not pointing at the #1 terminal, however the engine was indeed at 0 deg TDC.
Thanks
