Ship without the cable. That's a lot of weight for a non-unique part.
Build a plywood cradle- you can use cardboard too if you hot-glue layers together. The idea is to keep the winch centered in the box without adding weight. Also use the mounting bolts to mount it to the cradle, and to keep the end support in place. Use some of the air filled bags to keep the box from crushing.
Ship it dry, advise the end user to add fluid. You don't want to know the problems that happen when a box starts leaking oil...
Use a strong box, mark it heavy and fragile, use arrows to indicate top so it won't get rolled around.
Fed Ex ground will ship as long as it's under 120 lbs, IIRC.
