Longtime Fan
warbird
Lawrenceburg
KY
I've been a fan of the CJ8's since they first came out. I couldn't afford one in 82 when I bought my CJ7. I'm now in a position to give myself a second chance. My research indicates there are essentally two kinds of Scramblers left out there; restored (too expensive) and rotten (too much work). But, It also looks like there may be a third option. Couldn't you build a "new" one from scratch with aftemarket parts? You can land a new frame and body kit for around $8K. Drive train, steering & suspension, say another $4K to $5K. The motor of your choice $2K-ish.
You get the idea. With a little budgeting you've got a NEW truck for around $20K. My thought is to buy a completely rotten one with a good title and essentially replace it (instead of trying to restore one).
The in between ones are out there too....unrestored and in reasonable condition....I picked this one up two months ago...it has ZERO rust from California
I agree with Jason. Keep looking for a better starting platform. I picked one up a few years ago at a decent price that was a driver to start with. Even if you still have the plans to replace a bunch of parts, you can start with a decent platform and not have to replace as much or at least not as fast. Getting in and driving is where I get my enjoyment. Yes I have replaced stuff (luke an engine) but i am driving it and enjoying it everyday.
And doing the math in your post, for that amount you can buy a restored one.
Good luck. Search and be patient.
Dain.
At least buy another Scrambler for all the small parts you will need otherwise that 20k budget will not be nearly enought money. i am doing basically what you described minus the frame. I rebuilt the frame and replaced what was shot but everything else for major parts are being changed out for better and stronger items My budjet is 15-20k and I may have to make some comprimises even that that.
That's an interesting thought. Realistically, how much would the following packages cost, as new/newer components?
1. Tub, fenders, grille, hood, windshield, dash, doors, roll bar, bulkhead, tailgate, bumpers.
2. Frame, leaf spring kit, axles, driveshafts, wheels, skid plates.
3. Engine, tranny, t-case.
4. Steering column, pump, brake master, radiator, exhaust, fuel tank, pump, fluid lines.
5. Seats, belts, console, gauges, wiring harness, heater, battery, horn.
6. Paint, tires, rubber hoses, boots, marker lights, head/tail lights, top, flares.
7. Nuts and bolts.
8. Shipping
9. Time
AGREE !!! If you ever take a look at my build in the Complete Builds and Restorations; I started with a FREE Scrambler from my Father that was in Good shape. I ended up replacing the frame but the body and many of the stock parts were there and re-usable, some didn't even need restoration just cleaning(to include the engine and trans). And my budget of $7500 went bye bye half way through the build, I am over $15 K now and will end up just shy of $20K. The little things add up so fast, I don't even think I calculated in the cost of innumerable stainless bolts, nuts, washers, clamps, clips, wire loom, fluids etc.
My little Samurai is shot. :( The rust has sure enough set in and it has too many "issues" to make it a candidate for another rebuild. It looks pretty good from a distance but a rattle can will cover a lot of sins. It's also been rolled since this pic was taken.
With a Sami once the tub or frame has rotted out the rest is just parts. One of the things that's leading me back to the CJ is that it is possible to build one from scratch. Practical - probably not.
I'm really leaning toward building a rolling chasis with upgraded aftermarket parts while I look for a build donor. New frame, Dana 44/60 axles, coil-over front, and spring-over in back. I want a streetable truck I can wheel hard too. Not a crawler but a serious trail machine that can also haul & tow small loads.
Warbird, I just finished doing what you're considering. I had this...
- 1984 CJ7. The tub and frame were shot, motor was good but not what I wanted... sold most of it; kept some of the pieces and parts; kept the built/locked/gear axles, wheels/tires
Bought this - all new sheet metal (sold the wheels/tires, axles, interior)
4.5 years and a LOT of money later, have this - a brand "new" 1981 CJ8
forum
New drive train...
There is NO WAY this was the less expensive route than buying someone's restored or preserved CJ. No way. Granted, this is EXACTLY how I wanted it. But, I could've modified an already restored one too.
VERY NICE!!! Yall are just making me jealous.
I do put a high value on the "exctly the way I want it" factor. :D I'm wanting to go for a hard core WWII military look; Everything that can be painted will be OD. I know it's not particularly original but I like it (and so does my wife).
There was another member on here who did a Scrambler with a military look to it. I can't remember his screen name right now. If I find it I will post it or if someone else knows post it up.
Holy cow 53D!! That much even starting with a free Scrambler?!? Including the purchase price, I've probably spent $11-12K on mine, easy. That is not good news to hear.
Warbird, as much as you want something to look exactly as you want it, it'll be a heck of a lot less work if you start with a rolling chassis. I love your idea and I will be sure to watch how things progress. Someone here on the forum has a CJ in olive drab, it's been a while since I've seen it on the forum, though.
Maybe it's better to ask what parts of the Scrambler are you going to stick with? Would your goal be to wheel it or be a daily driver?
I added up my receipt pile last year...I had enough in receipts to buy a new Rubicon. :eek: Although, a new Jeep would have required a ton of work to get it to where I wanted it.
Seeing as you have specific plans for it, the biggest questions boil down to: 1. Are you going to do the labor yourself, and 2. Are you going to keep the powertrain and suspension in stock configuration.
If you are going to keep a leaf spring suspension, and an AMC powertrain, you might want to look for a restorable candidate, and go from there. If a link suspension and GM or other powertrain are in the works, an aftermarket frame might be a better place to start. (Especially the suspension- a non stock powertrain is somewhat easy to adapt.)
Likewise, if you are comfortable doing most of the work yourself, buying a basketcase and going from there is an attractive option. If you have to pay someone else to do the work, spending more for something that you don't have to change as much will pay off.
There's a third category- the abandoned project. This is often the best way to buy if you want something custom- you usually pay pennies on the dollar for this kind of find.
Any way- don't pay for stuff you don't need or plan on changing. You want OD paint- so don't buy one with good paint. If you're planning an engine swap, buy one with a bad engine, you can talk sellers down better on vehicles with "shortcomings".
I like to call mine a 2011 CJ-8. I also essentially built a new Scrambler: TDK frame, Aqualu tub, new sheetmetal, rebuilt a 401 that I already had that went in with a drivetrain that I already knew worked (Ford wide-ratio T-18, rebuilt 2x, bolted to a Dana 300, Scout Dana 44 front, Currie Tera-60 rear). I took down a CJ-7 (that had a YJ tub) for my steering column, wiring harness, guages, heater/air boxes, seat frames, and a few other odds and ends. The only CJ-8 specific parts that I had to acquire were the tailgate support brackets, interior rollbar brackets, exterior rollbar brackets, and the wiring channel along the left side fenderwell. I couldn't find the last two items and asked friends to weld them up for me quickly. Check out my build thread in my sig.
EDIT: The way things go, you'll be into it more than $20K by the time it's a driver.
It's the "odds and ends"/"little things"/"little parts"/etc that will nail you in the end. They're basically too small to really account for in your budget, add up faster than you could imagine and short of having a CJ of some flavor to pick them from, you'll nickel and dime yourself well over $20k in a hurry IMHO.
I think an abandoned project sounds like what you need to find and we'll be looking forward to watching it come together :D
I like the "abandoned" project idea and it appears they are not all that hard to find! I'm a retired USAF Crew Chief (B-52's & C-5's) so you might say I've been wrenching all my life. I couldn't begin to afford even a "practical" toy if I didn't. My Samurai was a carefully condisdered balance between a DD and a trail machine. I don't delberately look for obsticals when I'm wheelin just a way to get over, through, or around whatever the trail presents.
warbird,
Not sure how actively you are looking for a scrambler project, but I came across this one from rudys-cjs that was posted recently. Note that I have not seen this Jeep in person, just throwing it out there to see if it is a fit for you. I saw the listing and thought of your post.
http://rudys-cjs.com/jeep_parts_scrambler_tub_or_whole_scrambler_for_sale
He is selling the tub only or the whole Jeep. Not sure the extent of the rot on it. May be worth the price for all the all the aforementioned small parts needed for a project Scrambler. In any event I guess he is relatively close to you, probably a four hour drive north.
Hope this helps in your search.
I really like how thoughtful the folks on this forum are. I feel like I've tapped into a really great resource. It's especially nice for a "newbee" to get so much feedback. At this stage most of my (Sc)ramblings are just theoretical. My CJ-8 project is currently third in line awaiting attention from my piggy bank. It will be the same as any build - a compromise. How much can I bear to spend (saw one listed for $59K :eek:) and how long can I stand to wait to play with my toys.
Oh yea. Just adding in the big stuff:
TDK Frame: $3700 shipped (galvanized, rear bumper tire carrier option)
Body Work: $2300 for blasting/priming + $3400 for paint/rust repairs/liner
Wheels/Tires: $1000
Suspension: $1200
Wiring: $800 (painless + new howell EFI harness)
Gears/Axles/Lockers: $2600
That's an even $15k and doesn't account for all the: hardware, paint/primer for the frame/chassis, misc gaskets, sending unit, clutch linkage, brakes, fluids, SS line kits etc.
Oh and if you ask my wife all the shiney new tools I purchased to do the majority of the restoration myself and "save money" count towards the total as well. I think she's crazy though. :rotfl:
Warbird: I agree with everyone else...an abandoned project is a great option. Not only do you get a "clean slate" to build from, but you might get a screamin deal because someone is tired of having a torn apart vehicle just sitting in their garage.
