On its way...
timo439
BENEFACTOR
Gold Member
Portsmouth
NH
I have been lurking for awhile but I am psyched to finally have my scrambler on its way. It's on the truck and should be here by the end of the weekend. First thing is the full soft-top, new wheels, and getting rid of the light bar.
BTW, the winch, half top and bulkhead, light bar and current wheels will be available soon.
Excellent! Looks like a nice one! :thumbsup:
Glad to see you're set with a rig and looking forward to what you do with it :D
Wow...nice one. I like the colors.
WOW :drool:
That's a great looking Scrambler!! I'd leave it as is personally....but its yours not mine. :shrug:
I am guessing its from Arizona by the license plate? Some of the nicest vehicles come from that area of the country.
I have traveled to Arizona. for two of my past trucks.
Nice Rig....I'm jealous :crazy:
I saw that one on Craigslist and Ebay out here. Is it as clean as the seller says it is?
Thanks all. I am still guessing at what size lift is on it. I am thinking 2.5 or 4...
I did have one of the guys from another forum check it out. He spent a good amount of time looking it over and gave the thumbs up. It is going to be a DD, so I know of a few minor things that need to be addressed and I am sure other will pop up, but I got a much better deal than what it was listed for, so I have some room in the budget.
What size tires are those? Got a frame/body shot that shows if there's a body lift? Looks like it might have a small body lift from the picture of the back...
I should change the title to "It's here!". All is good with it except it won't stay running without my foot on the gas. My guess is the carb needs some tuning. Since I am carb illiterate, I now have to start the search for a good carb guy. Anyone have any suggestions in the Portsmouth, NH area?
BigWalton - the tires are 31x10.5's.
Thanks
Tim
I wouldn't run it off to a carb guy so fast unless you just have to try to have it running ASAP.
Could be a number of things from simply a dirty fuel filter to bad gas to a bad fuel pump to a vacuum leak, all of which you could check for yourself.
Do you know when it was last running right? Was it sitting for a long while before you bought it? If so, I'd get the gas out of the tank and put in some fresh stuff, take the fuel filter out, run a line from the connection at the filter to an empty gas can and crank it over a bit to flush out the line, then install a new filter and see what happens. None of that is expensive, it's all a good idea anyway and it's pretty simple, might have you running in an hour or so.
Next would be to check for a vacuum leak, which can be done by slowly moving the business end of a small, UNLIT, but cracked open propane torch around the top side of the engine while it's running. If you hear the RPMs pick up, you're close (propane ups the fuel/air ratio that's too low because of the extra air from the leak and it increases RPM).
Others here probably know other things too, but these came to mind for me.
I had a guy from JeepsUnlimited take a look at it and he mentioned it was running well when he took it out. It has been sitting for about a month before being shipped cross country last week. I will probably go ahead and do the basics as you suggest and hopefully will be able to solve it. If I need to get into adjust idle speeds, etc... I'll find an expert.
Thanks again.
Btw - I ran the part #'s on the leaf springs and it has a 4" lift.
In that case I'd highly doubt that the carb somehow got out of whack since the dude test drove it (idle speed won't adjust itself). Probably didn't pop a vacuum leak in that time either, seems a lot more likely that there's something about the gas/pump/filter that would be the issue. Might throw some carb cleaner in the tank when you put in the new gas too.
You never know with CJs, but I'd suspect gas delivery of some flavor if it runs fine at everything but idle.
Hopefully some folks who know more than me will add their two bits too :)
EDIT: what brand lift? Hopefully that's good news for you regardless :thumbsup:
It's a superlift. Throws the jeep all over the place...
I'll let you know how it turns out.
If it runs fine anytime except idle and it has the stock carb, clean the idle tubes:thumbsup:
I only have a few pics so its a bit of a tease, but after awhile down with Toybox and after my trip down under, the jeep is almost restored... A slight change from when i got it but its the original factory color.
