- Cobourg, Ontario, Cana
- da
Installed Speedway Motors headlight relay kit. Really impressed for a $38 kit. Wires laid out perfect, well protected and the connectors fit well. 20 minutes from hood up to test drive!!!
Did you do a separate thread on it? I hate to think that good stuff like this and the Gr8tops trunk are buried so far down in this one honking long thread![]()
Just finished installing another rear axle shaft into my rear AMC23. Took the easy way out, a used shaft with seal and bearing already installed. The old one was leaking, found the seal had "blown out". Weird. Axle vent is unobstructed. Inner seal had lost it's spring, floating on the shaft. I removed the inner seal, I'm going to let the gear oil lube the bearings.
Also grabbed this pic of the Scrambler at the office with the smoke from the Idyllwild fires burning down the hill. Looks like the apocalypse here in 29.
I agree. It looks awesome. The colors are just great.
