Harbor freight use once throwaway
Seems relevant to this thread:
I have that transfer pump. It is frustrating because you have to hold the hose on the pump, BUT if you can get those 3rd and 4th arms in play to hold the hose, hold the pump, manipulate the pump handle, and hold the other end of the hose into the whatever you're filling, it works great!
O this is good.. im going to print it out and share with my crew...
Sent from my SPH-L900
Ill let you know tonight if I chuck it down the driveway.....lol
I got a little doohicky at wal mart that you can attach to the top of a 1qt bottle of gear lube. It has a hose on it about 20in long and a valve you open by twisting the base. Used it to top up my T-case, worked well. You may have to squeeze the bottle a bit. I think it was only about $2-3.
Well it worked but like u said had to hold it together.. I cut down the hoses and worked fine.. I didnt take the chance of using it twice so I chucked it.. lol. Well worth the 5 bucks .. 10 min job.. I recommend it in the tool box...
Ive had mixed results like most but my best HF story is this one:
I was in line behind some 'undocumented aliens' whose mastery of even the local English dialect was marginal. They were returning a couple of tools, large things likd a jack, set of stand s or something and a couple other things. So the kid behind the counter is trying to do the return stuff and cant figure out the reason for return, the customers couldn't, or wouldn't, communicate so the kid calls the manager over, he looks at the customers, asks a couple questions and tells the kid 'mark it D.U I...'
Well I'm pretty good with TLAs usually so I'm trying to figure out DUI.... the manager looks at me and smiles and asks 'trying to figure out DUI arent you?' I admit he's got me stumped with it and as the guys who had returned the stuff left he leaned in and said; 'Done Using It..." laughed and walked away
Bought a set of allen wrenches and they immediately rounded out like butter.
Bought a set of shorty swivel rachets and the rachet cogs gave way and broke my knuckles the first time I used them.
Bought a 500 count tube of zip ties and they zip back and forth nicely without locking.
Bought a set of air chucks for my air compressor and hoses and they leak like sieves.
Last straw was buying a 4lb shot mallet and a rubber mallet. The shot mallet broke in half the first time it was used and the rubber mallet delaminated and broke after one year.
Done.
Bought a many-LED flashlight at HF maybe three years ago. Wasn't dirt cheap, but it still works fine. As many of you are saying here, you have to pick and choose the kind of stuff you buy there.
Just bought the HF #60827 Ball Joint Service kit. Will be using to replace joints in my Dana 50 IIF front end. Hopefully this weekend.
Will let you know how it works.
Please do. I need a ball joint kit.
I've got one of their ball joint tools. Works fine.
Stay away from their welders....
I've used their ball joint kits. They work great and hold up just fine. I think they are the same OEM manufacturer as some of the other "not quite Snap-On" brands like Performance Tool, etc that are priced between Harbor Freight and the high end stuff. I borrowed a Performance Tool set from the local auto parts shop and the price on that was like $130 and I am nearly positive it is the same as HF. Good luck!
Used it tonight. Removed and installed 4 ball joints. Clamped it upright in a vice. Then went to work. PB Blaster pre soak. Only drawback was one of the joints was too long for the adapter. Just happened to have a piece of pipe with the correct id. Cut a piece just the length needed. Worked great.
Pressed out and pressed in new joints in the front axles. Beat using a vice and sockets. Again an overnight pre soak with PB Blaster.
Bought an electric panel saw two years ago, the chuck broke a few weeks back, HF exchanged it for a new one. $35 for a tool that got beat for two years, then replaced free... No problem there. on the other side, I have had a few other tools from them die early deaths. Their radial miter saw is crap. Under powered and smoked the motor in a week.
I have been using their 14" metal cut off wheels and 4 1/2" grinding wheels for years without any problems. I buy them in bulk when we go to visit family in Albuquerque. They are much cheaper than what I can buy locally and they seem to work just fine.
