33's with 2.5" lift or 4"
That was when I was in between deciding on tire size so what you see on the back is a 32 mounted on a 15x7. Ultimately what I did was sell the 15x8s and 32s shown and took the 31s off this jeep:
Which is a good jeep to talk about 'cause that's a 3.5 inch rubicon express lift with 31s and 15x7 white oem rims.
It then got these 32s on 15x8 aftermarket rims:
Same jeep can show the different looks you can achieve by looking at the pics side by side. By the way I often think that a good compromise between deciding on 31 or 33 is to just go with the 32. To me it's the ultimate size , sometimes to me 31s look to small and 33s either look too large, rub, hurt power and gas mileage etc... It all depends on the lift, the look, and what u are going to be doing with it. :thumbsup:
Great posts! I am getting ready to lift my cj7 about 2.5" the only problem I'm having is trying to figure out how to fill the wheel well more, my cj7 is a 1980... so narrow axles. I think I may go with a 15x8 wheel and 32 x 11.5
I preferred it that way too. But I couldn't find any old school BFGs without buying them new so they got donated to the overlander. The black rims and 32s were a bolt on from a rusty jeep that got scrapped. Ill prob go back to something like that cause while i like the look of the pro comps they are one of the noisiest tires I have ever driven on. Worse then the 80s wrangler MT if you can believe that.
I hear you on the narrow tracks, I think a 15x8 and a 10.5 wide tire at a minimum is required to look right. Here is a 1980 CJ5 I used to own, with said rims and 31x10.5. The lift is a 2.5" skyjacker circa mid 90s. The pic is 2011.
Sent from my Big as My Face Galaxy S3 Note.
Sorry. Still trying to figure out this newfangled phone. That is 2-1/2"OME, 1/2" shackles, 1" body lift, 32x11.5x15 BFG ATs on 7" stock rims.
Wait. No it isn, t. That's the before shot. Try this
Here is my '85 CJ7 with Firestone Firehawk 32X11.50. I agree with some others on here that the 32's really do seem like the best tire for filling the wheel wells of a relatively unlifted Jeep. This CJ had only an add-a-leaf in the original spring pack. Now, keep in mind that this photo is from 1995 or 1996. I have 31's on my Scrambler today and very high gearing (2.73). I plan on moving up to 32's but I am afraid I will need to regear to go to 33's so I am not going to risk it. Not ready to regear yet.
That is also my wife about 8 years before we got married. On the way home from the Oklahoma salt flats (where we are in the photo), the capture bar across the top of the window pulled free in a rainstorm and a severe temperature drop. Just another memorable trip in the Jeep.
I have the same gearing thoughts going on about mine. The PO put 33x12.5's on it and really no lift that I can tell unless the body has been lifted. I put some Boomarangs that give it a 1-1.5 lift but it still rubs when you get up on a rock.
But that is another issue. The gearing with 33's and my 2.73 (TF999 Auto) is pretty good. I put in a 4:1 LowMax conversion and am happy with it about 95% of the time on the trail. Those long downhills are still a problem IMO. With the 4:1 there is plenty of power uphill crawling...sure more gearing would add to that but it is perfectly acceptable. At what point do you power through your manual brakes 50:1 crawl 75:1???
I don't really want to mess with it because it can run 75mph down the road at 2100-ish rpm and get 16mpg. If I regeared (3.73 or 4.10) I would put in another Auto with an overdrive (Chevy) so I can get close to that RPM range. Don't think I'll go back to a manual after wheeling rocks for a year in Autos.
Jim,
Here's mine on 4" BDS Lift with about an extra 1/2" from the MOORE Shackles. Tires are 33" Duratracs.
Here is mine with 33X12.50 on 15X12 wheels and narrow tracs. 4" Skyjacker Softride and 1 inch body lift.
:wave:
Jim,
If that's a 4" lift with a 1/2" extra in shackles, it's about 2-4" taller than my 4" lift kit. That is an awesome color/decal combo, and probably my favorite! Something is off on the decals, though, but I cannot quite place it. What manufacturer supplied the decals for you?
Hey now, I run 33x9.50 BFG MT on my '81 Scrambler Laredo with N/T axles and I think it looks better than my 33x12.50 PC MT on the '83 Scrambler Laredo with W/T axles. Oddly, I swapped them across once and the width fit each other Jeep perfectly within the fender flares. I just don't like the way 12.50 wide tires fit slightly outside the fender flares on W/T axles.
Do you have a pic of the Scrambler on the 33x9.5s? I am thinking about not going wide if I go to a 32 or 33 inch tire next time. Thanks.
Dain
I'm running 265 75 16s GY Duratracs with a 1" body, 1/2" shackle lift on wt's.
I love the fit and look
