Scrambler Guy
- Jacksonville
- FL
Hello Scrambler Folks,
Have any of you with the 4L60E transmission had any problems? I don't know why but I about to loose my second transmission.
I have a Chevy 4.3 vortex v6 mated to the 4L60. The Jeep currently has 35's but when I lost the 1st trans, it had 33's. It has 4.56 gears in the stock axles and a 4" lift kit, if that matters.
My problem starts with the trans overheating (220*+). It starts overheating at highway speeds, then, over time, progresses to any speed. It always shifted fine. After a while, it started slipping and giving me more trouble. I had it rebuilt. I don't know if it was shot or they rebuilt it poorly but it blew up in a few days. I got a replacement trans.
Now the new trans is starting to give out. I replace the 33's with the 35's at this point. Note: it was overheating before I put on the tires. To help curb the issue, on the 2nd trans, I installed a trans cooler. I just had the temp sensor moved and it shows that it's still overheating. A new symptom is funny shifting. Fights going into 4th and rpms fluctuate, slipping, I suppose. A local mechanic said it the cooler didn't fix it, I needed to change the axle ratio. I don't think that's the issue.
Talking on a GM Truck forum, it was suggested that the 4L60 isn 't stout enough to handle the tires and gears. I can't help but think there is something else going on. I'm afraid to replace the trans with another 4L60 but upgraded and have it die on me too. I'm also concerned if I go to a 4L80E, that the same will happen there.
Any advice or thoughts would be greatly appreciated. It's looking like this transmission is getting ready to go soon. Sorry for the length.
I have to make a plan soon as this is my daily driver.
Scott
Scott
If the TC is slipping all the time at high speeds, I believe the transmission will overheat
