4L60E Problems
Scrambler Guy
Jacksonville
FL
Hello Scrambler Folks,
Have any of you with the 4L60E transmission had any problems? I don't know why but I about to loose my second transmission.
I have a Chevy 4.3 vortex v6 mated to the 4L60. The Jeep currently has 35's but when I lost the 1st trans, it had 33's. It has 4.56 gears in the stock axles and a 4" lift kit, if that matters.
My problem starts with the trans overheating (220*+). It starts overheating at highway speeds, then, over time, progresses to any speed. It always shifted fine. After a while, it started slipping and giving me more trouble. I had it rebuilt. I don't know if it was shot or they rebuilt it poorly but it blew up in a few days. I got a replacement trans.
Now the new trans is starting to give out. I replace the 33's with the 35's at this point. Note: it was overheating before I put on the tires. To help curb the issue, on the 2nd trans, I installed a trans cooler. I just had the temp sensor moved and it shows that it's still overheating. A new symptom is funny shifting. Fights going into 4th and rpms fluctuate, slipping, I suppose. A local mechanic said it the cooler didn't fix it, I needed to change the axle ratio. I don't think that's the issue.
Talking on a GM Truck forum, it was suggested that the 4L60 isn 't stout enough to handle the tires and gears. I can't help but think there is something else going on. I'm afraid to replace the trans with another 4L60 but upgraded and have it die on me too. I'm also concerned if I go to a 4L80E, that the same will happen there.
Any advice or thoughts would be greatly appreciated. It's looking like this transmission is getting ready to go soon. Sorry for the length.
I have to make a plan soon as this is my daily driver.
Scott
Well first I have a 4l60e with 33 and 4.56 gears. It has aftermarket bm lockup converter not high stall. I been running it for over 10 years on a fresh rebuild. I installed a rail type cooler and mods on the trans are billet servo. I been pulling trailers and road trips all that time and never yet (knock on wood) had a problem with slipping and strength. . To me your problem is over heating air flow and maybe the wrong converter. Yes 4l80 are better but I havnt had a reason to switch off yet.. and probly wont.
Sent from my SPH-L900
Also I have to add is shift points have to be set to what gear ratio and combo like camshaft and hp.. computer most def has to be flashed. Have u had the computer programed for your spec
If you have the 4L60, the TV cable setting/adjustment is crucial. I would have this set by the transmission shop, using the pressure gauges:twocents:
If it is overheating/RPM's fluctuating, could be the torque convertor not locking up for some reason:shrug: If the TC is slipping all the time at high speeds, I believe the transmission will overheat:twocents:
Have you plugged in a code reader to see if you have any codes dealing with the "TC lock up" or "Top gear switch"???
On the 4L60, you can change the governor springs to alter the shift points. I would not try to alter the shift points via the TV cable setting, seems like a really bad idea:twocents:
Your right I reread it .. but the title says e so im sure he will revise it so we can help him.. funny how a letter changes everything lol
Yep, that little "E" makes a big difference:cheers:
Sorry, it is a 4L60E, I took the E off as a shortcut. I hope to get it to my mechanic, he's not a trans specialist but he does a lot of work on them. I'll ask him about the re-flash and check the codes and program it for the gears. Should I have him program it any specific way? I have not done anything to the computer since I bought it 10 years ago.
I should note, it doesn't slip all the time, it's infrequent and always after it warms up. It currently doesn't shift into 4th almost all of the time, so it can't lock up.
If I'm going to keep the current trans, what upgrades should I do?
Hey! Can you tell me more about your 4L60e mods? I am looking to switch to a current gen GM drive train and am wondering about any changes I need to do to the 4L60e to make it work with what I have. I would like to keep my AMC20 axles just because I already have them. I drive tons of highway so would 4.56 gears work? i hear lots of folks wanting to move to 5.10 gears, but they do not make those for the AMC20.
I could go to Dana44's, but for now, I have to pay for the engine and transmission! One thing at a time!
I'm running a 4L60E with 4.56 gears and 35" tires. 2 years and no problems. Radiator cooler plus and extra 15000 GVW cooler, fluid is still bright red. And I'm not easy on it either. Cruise RPM at 60 is about 2000.
Sounds like it's either built wrong, or programmed wrong.
What Randy said... Build thoroughness or parts used or program issue.
If never changed the original program may think you are running as high as 3.42 gears with 31 inch tires. That would be hard on torque converter over time if you don't dissipate enough heat.
