Back fires through exhaust
MoabCJ8
Lehi
Ut
Having an issue I cant seem to figure out. Jeep runs and drives perfect but if you rev up the motor and let off quick it will back fire through the exhaust. I have replaced the intake/exhaust manifold gasket thinking that was it but it made no difference.
I tried disconnecting the plugs one at a time to see if a certain cylinder was doing it and it did it not matter which one I disconnected.
It is a rebuilt 258 with the original Carter carb. Everything looks tight and perfect.
Possible things I have been thinking of:
-Carb adjustment
-Spark plug.
-Low octane fuel
Any ideas or first hand knowledge of this problem?
mysunnshine
Phoenix
AZ
I'd say an air leak in the exhaust or really short exhaust.
Sent from my SCH-I545
MoabCJ8
Lehi
Ut
I purchased the Jeep about a month or so ago and have been restoring/building it.
Haven't driven it more then a mile so far but this is one of its little quirks that are bugging me.
Rosco1974
BENEFACTOR
Gold Member
Oklahoma City
OK
Timing? What is it set @ and was it checked warm with vacuum advance blocked off?
John N
Addicted....Ex-SOA VP
BENEFACTOR
Gold Member
Rockville
VA
Yeah that.....check the timing.
b.b.chev
Black Forest
CO
Does it still have the air pump hooked up ? When I was a car mechanic I used to run into bad diverter valves causing this problem .
Kim Dawson
Member
Molalla
Or
Might do a compression check and make sure a valve stem isn't bent or something holding a valve open.
MoabCJ8
Lehi
Ut
looks like b.b.chev is correct. I disconnected the pump and it stopped back firing.
