Back fires through exhaust
MoabCJ8
Lehi
Ut
Having an issue I cant seem to figure out. Jeep runs and drives perfect but if you rev up the motor and let off quick it will back fire through the exhaust. I have replaced the intake/exhaust manifold gasket thinking that was it but it made no difference.
I tried disconnecting the plugs one at a time to see if a certain cylinder was doing it and it did it not matter which one I disconnected.
It is a rebuilt 258 with the original Carter carb. Everything looks tight and perfect.
Possible things I have been thinking of:
-Carb adjustment
-Spark plug.
-Low octane fuel
Any ideas or first hand knowledge of this problem?
I'd say an air leak in the exhaust or really short exhaust.
Sent from my SCH-I545
Did this just start or have you "done" something to the engin recently
I purchased the Jeep about a month or so ago and have been restoring/building it.
Haven't driven it more then a mile so far but this is one of its little quirks that are bugging me.
Timing? What is it set @ and was it checked warm with vacuum advance blocked off?
Yeah that.....check the timing.
Does it still have the air pump hooked up ? When I was a car mechanic I used to run into bad diverter valves causing this problem .
Might do a compression check and make sure a valve stem isn't bent or something holding a valve open.
looks like b.b.chev is correct. I disconnected the pump and it stopped back firing.
