What did you do with your Scrambler today? April 2014 version
Started reassembly in preparation for bringing her home!
2, proofread and cleared by the NSA.
Last major piece of preparation for the Moab trek on the Postal half done: new master cylinder to replace the leaking one and hopefully firm up the brake pedal. Need Kate to help bleed out the brakes tomorrow.
Also pecked away at cleaning things more under the hood.
Swapped out the bolts that hold the half top frame to the tub to pins with wire hooks. Hope they don't rattle too much. Should make the top quicker to take off.
Was
Now (except the wire is looped around the back)
Dain
Was
Dain
Wow, that is so different than the frame design of my Kayline 1/2 top. Pretty creative use for a pin release... bet it will save you some time.
Yeah. Took about 2 minutes each side to undo them. So that is 4 minutes saved each time I want to take the top off or have to put it back on. Oh and 2 less tools needed! Every second counts.
Dain
Did you/will you do a technical writeup on this? Part numbers, donor vehicle info, procedure, observations, etc...
Going to be doing hydro brake conversion on my Scrambler soon myself and could use any kind of detailed information possible.
Thanks:wave:
I tried to send you a pm on some of the specifics but your inbox is full!
I will post some of the part numbers and items needed when I get a little time.:crazy:
I have never been into the lowriders and never knew the slang/lingo, but is this what they call tuckin 31's?
I took the nose off so I could get at the 401... the fenders were "too high"... heavens no!
I also got the carb, exhaust manifolds and distributor off and on the bench for pictures to be sold off... picked up a set of hedman hedders for it as well, so I want to try and fit those along with some old wires and such that I have, just to see how it all goes together.
401 logo... barely...
It spins over freely as well with a little lube in the cylinders, so that is good... I have a lead on some aluminum heads and an edelbrock intake, so I hope I can nab them soon.
Got a chance to install the stainless brake lines and proportionate valve. Bent and mounted the fuel lines. Now I get to take the fuel lines off and paint them. Slow but surely coming together.P1000916.jpgP1000917.jpgP1000918.jpgP1000919.jpgP1000920.jpg:bacon:
Removed the stock steering shaft today. The darn thing would not collapse and I couldn't get it out so out came the trusty sawzall.
I won, it came out.
Also painted the borgeson steering shaft so I can install it tomorrow.
Drove it! It was 45 here this morning and after dropping off my kindergarten daughter in the nice and comfy Tahoe I came back to get my 2 middle schoolers. My 12 year old daughter agreed to take the Scrambler (even though the top is off). She sat in the back seat buckled up with a blanket wrapped around her. She looked like ET. They had a blast! The middle school is maybe 2.5 miles from the house. Then I had a 15 minute drive to work from there. Simply switched out which hand I sat on every once in awhile... I had a blast as well! And the drive home after work was 65 and blue skies.
Actually this was Saturday but I've been busy between now and then. We took the Scrambler up to the Ochocos to look for wild mustangs and scout for camp sites . Found both! Had a great time, the Scrambler averaged 16.5 MPG! Even with a ton of slow crawling around. Mostly trail riding, nothing that locked 2wd couldn't handle. But, tons of fun!
A beautiful stallion
Exploring an abandoned old cinnabar mine and the old motel nearby. Really neat stuff- there's mines like this all over this area!
A nice campsite
All in all a great weekend!
"Exploring an abandoned old cinnabar mine and the old motel nearby. Really neat stuff-"
Is that the mine where they get the cinnabon from?? Yum.
Sent from my SPH-L900
Sounds like it, doesn't it? Supposedly, Cinnabar is red and tastes like cinnamon. However, it is toxic. Cinnabar was mined and then refined on site to produce mercury, which was used to extract gold from ore.
If you're interested in a quick description with nice pictures, look here- http://www.photographoregon.com/Oregon-Mines.html
I didn't know before I read the attached article, but the hotel was called "The Four Horsemen Hotel", and the mine is the "Blue Ridge Mine". Pretty cool. I am looking forward to exploring the others.
Cool would love to take a trip to see that one day... among other places..
Pulled the trigger on a rear Rock Hard Scrambler Sports Cage today.:thumbsup:
Last night I installed the Borgeson steering shaft and replaced the steering column bearings while I was at it. Painted it prior to install.
Also picked these up from the powdercoater...
Can't wait to get these installed. They look awesome. Just need to figure out where to drill the holes :)
