What did you do with your Scrambler today? May 2014 version
CHIEFWAHO
Former SOA VP
SOA Board Member
Thayer
KS
Ready for Moab
Busy day...
Installed my 2nd battery using a Tomken one piece all steel (welded) battery tray (hell built for stout), and an NV Wrangler solenoid. I still need to clean up the additional wiring but it already looks a lot better. Now I can cruise the desert at night and not worry about the KC's draining my battery, not to mention the 8274 waiting for its new home!
I also installed some neat flood lights that mounted to existing light tabs on the roll bar, I assume originally installed by the PO. These lights are super bright and throw a WIDE pattern and are absolutely amazing when creeping through the desert washes at night... unless of course we come upon a zombie hoard. Sometimes it's best not knowing what's lurking in the dark.
The CB installation was finally completed including the proper tuning of the antenna, all in all I am very happy with the set-up and it is out of the way.
Last but not least, finished installing a new 12volt switch panel from Prime 4x4. I did not like having 4 different styles of light switches under the dash, I am waaaaay to anal for that!
well i put the full hard top on the scrambler last night but cant show you any pictures as i left my phone home!! don't you hate that....
Still scrubbing away on the underside of the almond beige Laredo and getting ready to install the auto-trans Lubelocker gasket. Installed new o-ring on the dipstick tube and have found numerous little "foibles" from the previous owner but far fewer than most. I'll snap some photos of the frame this weekend--it cleaned up to nearly new and has zero rust. Even the gas lines and brake lines are like new. Hoping the auto shifts alot better after all of this work and the new mounts--next is replacing the valve cover gasket and getting rid of the seepage there. One of the cleanest Jeeps I've had.
In Utah! Drove it out of the Maze to Hite and then here to Hanksvlle. 164 miles in low gear since Monday.
Electrical!
Finished addition the auxiliary fuse box, which finally allowed me to clean up the wiring inside the engine compartment.
The fuse box came from Westmarine, I decided to mount it to the battery tray using some aluminum bar stock that I had on hand.
Measure twice... drill once.
Front view of the fuse box.
Back side of the box mounted to the battery tray.
The fuse block mounted up and ready for wires.
The completed project, everything neat and tidy!! I even got to use my new DYMO labeler with heat shrink tubing... are ya kidding me!?! :smokin:
Now all I need to do is drop the relays for the H$'s and KC Daylighters a little lower down in the fenderwell to make room for all the plumbing for the on-board air system... all in due course.
Seriously awesome stuff. Want to come clean up my wiring? Soooo jealous.
Dain
Used the '8 to hook a chain to our Exmark mower that the driver, not me, got stuck in the stream running in our front yard... Happens once or twice a year trying to get too close on a sloped part of the grass.
No rule #1 as I would get hurt...;)
Same brand book I used under the dash. Love it!
Ran to the Denver airport to get the wife and kid and then went an amazing back road to Breckenridge for the night.
I got the spare tire carrier (Craigslist buy) cleaned, welded up a few weak spots, then painted and mounted with the spare. Need to pull a stud where the pipe comes into the manifold, replace and tighten that up, then a water pump (it works but is pretty noisy so going to be proactive). Attended the Cars & Coffee get together in the El Camino with the Chevelle buddies. Had the confirmation service for my 12 year old daughter, dinner with a big group of great friends followed by a Cinco De Mayo party to round out the day. A great day!
Went to pick it up from the spot it refused to start for me yesterday. Fired right up. Grrrrr.
Was acting like it could not get fuel yesterday. Usually it happens after a refill but I can pump it with gas and it starts. No dice yesterday and killed the battery trying. Took the expedition to jump it. Did not have the fuel issue and vrooom. On my way back home.
Then I had to field questions from my wife about owning old and unreliable vehicles.
Dain
Awesome wiring job!
I have to get one of those label makers. Next business expense.
