What did you do with your Scrambler today? May 2014 version
Of course I don't have action pics of myself, but we ran Poison Spider Mesa today.
OUT!! :)
Here my Hell's Gate experience.
It's not MOAB but fun the same.....
Top of the Ozarks Jeep Jamboree
Great fun so far until I tweaked the engine tranny aligned on a with a rock and a bad engine mount
Started pulling the intake and exhaust manifolds this evening so I can replace the exhaust studs on the pipe side of the manifold. 1 nut was loose enough to where it would not bite, that one came off easily. The second one simply snapped off like I expected. Glad I bought the helicoil kit a while back. And will finish that all up with a new water pump and thermostat.
Drove from Moab to Colorado Springs...
Ended up with a new exhaust manifold, reinstalled exhaust and intake, new water pump, new belts and new hoses. I had a VERY annoying exhaust leak after firing her back up. After tinkering and thinking I noticed the issue. I bought the gasket from CB. It had an additional paper gasket laid over where the intake ports go. Noticed that to make that 1 piece they had gasket material running up and over the exhaust port. Well, they cut the corner short across 2 ports. So loosen all bolts and got out the razor knife. A lot better. Still a small leak somewhere but she sure runs better. Will post a question under the engine forum now that everything is quieter and can hear another noise....
OK.........so how do you get a picture of the scrambler cruising the highway while you're driving? ?????
The mountain pass we were on was closed up ahead. You can see my footprints in the snow. I was out of the Jeep for 30 seconds to take the pic, i looked like this when i got back in.
Stopped to see Starkebaum at 4x4Land in Topeka KS. Big Walton was there too!
Changed out the brand new Tom Woods drive shaft that I put in in Moab. Failed Ujoint after 900ish miles. NOT INPRESSED.
Cheap chinese components.
