What did you do with your Scrambler today? May 2014 version
I'm slow sometimes... What do you mean by "someone photobombed your shot?
Just that someone is in the background of your pic. Most likely unintended. Photobombing is popular where when you see someone taking a family photo at a theme park and you jump into it in the background and throw up a peace sign with your fingers as an example.
Dain
Yeah. I told you I'm slow. That's my 12 yr. old son. He was enjoying sporting around in the red one. He likes the Scramblers.
Figured it was your son. They are notorious for getting in photos at my house. My son has started to enjoy my Scrambler as he has gotten older. He used to be afraid of falling out. Now he is 14 and much bigger. So he feels safer now I guess.
Dain
Drove around in the red jeep today.
Love the way this looks! Someday my red 81 will look this good, hopefully!
Thanks! This is my weekend, sunny weather, no chance of rain Scrambler. I look forward to following your build.
Thanks. Going to be a while though, looks like I'll be moving at the end of the month and building a ship before any work gets done on Red.
ordered my 17x8 lifetime shed from lowes this morning for my jeep parts :)
I've been scrubbing and cleaning the 82 Beige Laredo and getting it ready for sale. I'm finding it's an uber-clean Jeep as I remove the accumulated dirt and dust on it and under it. The paint has cleaned up nice but has the usual nicks and scratches. The frame is nearly rust free save for some spots of surface rust (very few). I swapped in the components for the v-belt system as I wanted the serpentine for my dark brown metallic 83. It came out nice--new alternator, fan clutch, water pump, belts, and so on--gotta do something about that raggedy fuel line though, looks like crap! Will post more pics this week.
I diagnosed my column problem to a failed upper bearing. However, with all the other problems with the column I decided to go with a remanufactured column from Columns Galore:
http://www.columnsgalore.com/N6.htm
Mechanically it seems like a 10. Appearance wise I would only give it an 8. Looks like it had some rust pitting on it that they didn't take care of before they painted it. When/If I do a frameoff I would want to fix that.
I also went with a new steering shaft at the same time from Borgeson:
http://www.quadratec.com/products/56113_912.htm
I actually went with 2 :banghead: I've never done anything this involved before and I made some mistakes that forced me to get another shaft. Guess I learned the hard way, but the important thing is that I learned and it's all together and working. I've mentioned my loss of steering anxiety before, so as you can imagine I was a little nervous the first time out after changing so many components. So far, the column is bone tight and the steering seems improved. Wheel is also more centered now. I'll have to drive it again to see if it needs adjusting with the drag link.
One question. Would a realignment be in order?
Shouldn't be with just a column and intermediate shaft swap. Only realignment (toe set) if the tie rods were replaced. You can adjust the drag link to center the wheel without changing any alignment specs.
Signed a credit card bill for $588, cha-ching!
After mounting the 8274 it became obvious I had serious cooling system issues. Radiator started leaking, engine got so hot the fuel injection started cutting out, almost leaving me stranded. All in all not good. Shop ended up replacing the water pump, resurfacing the thermostat housing (pitting in the housing and head was causing leaks around the gasket), new thermostat, rodded the radiator (flows were about 60%), patched two holes in the upper tank, ditched the flex-a-lite fan blade and replaced with a Ford 5 blade fan on a proper clutch mount.... I'm sure I am missing something else. Oh yeah, added a resistor to the temperature sensor so it would read correctly at the gauge.
Radiator shop initially told me I had to lose the 8274 :eek:, and I said no way! I think we have a workable solution in place now, just need to get to the desert tomorrow for some slow speed crawling and see how she does, temps are supposed to get to 110 (and it's only May!). :huh:
Finally got the Dana 44 in from Kenny in NC. Haven't inspected the guts but it's well worth the wait in my eyes--the unit is rust free and not pitted at all like so many of them. Thanks Kenny for your patience. Dave.
Made it home. 6013 miles and 12 hours short of three weeks.
Double Blanton's to celebrate.
