What did you do with your Scrambler today? July 2014 version
This is too funny! I bet the cashier is also flipped out.
Also hit McDonald's for a celebratory breakfast, driving through backwards like a RHD boss. The look on the dude's face in the F150 was worth the trouble. Strangely enough, drive thru designers always assume the steering wheels are in front.
Pulled the donor trans out tonight for the 1985 (white one in the garage)
Looks like somebody set a trap for JJ
Are you sure there's not a string attached to that stick
Got the auto pedal assembly and non tilt auto column removed and a manual tilt column and pedal assembly installed
Eric,
What's the reason for swapping the Trans and steering column in the '85?
Seems like a nice preserved Scrambler, so was surprised to see you swapping parts?
I am making this one my run around scrambler. Its decent, but its not too nice to modify. The hood letters are scraped off and cuts through the paint from the PO, faded clearcoat, and its got little bruises here and there. And the main reason - I really dont like automatics. So I am adding the T176, and at the same time a tilt column. I might even lift it up a little and run some larger tires.
Ahh, gotcha!
Thought perhaps it was a manual that someone previously swapped for an auto.
i replaced my belts in hopes of getting the AC to work, failed on that front but it has new belts! big whoop huh?
I dropped off a cam, lifters, timing set and various gaskets, fluids, and filters to my engine guy. Hope to get the Jeep motivating itself soon...
Hey, Jersey- what are you doing with the auto brake pedal?
2, proofread and cleared by the NSA.
Today I finally brought Red home. I've been sort of absent here for the last few weeks- let me say that we are in our new home after dealing with the mortgage company from hell. Anyways- there's about a good summer worth of projects around here, but I really wanted to get at least one of my storage units vacated. I'll make a "new place" thread at some point when I have the time and energy.
Here's Copper towing Red home.
And at her new home, until I can start working on her.
We painted and installed the top. Then removed the the hood to take care of the rust issue. image.jpg
Our 2nd polar vortex of the summer has produce a week of 80 degree days. How many days can I drive the scrambler to work?
