Buy a used 8274.
Rebuild it.
Not hard at all.
Great winch.
Used ones can be had for $200 - $300 working.
Just become a Craigslist squatter. One will undoubtedly show up.
Just depends on what condition it's in if you find one.
Solenoids and wiring to them are usually the main thing that needs attention.
Otherwise, not a whole lot other than changing the oil in them.
If you are unfamiliar to the 8274, they have an oil reservoir (the gear box housing) that requires a minimal amount of oil.
Synthetic rope is great option for upgrade.. Takes a lot of weight off the front end.
Sent from my SPH-L900
I am quite familiar with the 8274 but man.. expensive! Frankly, I will very rarely use it. What about this one? Warn 88990 ZEON 10.
Thanks
Plus, it does not block up the radiator as much as an 8274.
Warn 9.5 ti
Great for moving stuck JK's out of the way, too
Lighter, faster, more efficient, then an 8274, and no stupid plastic solenoid box that lets water inPlus, it does not block up the radiator as much as an 8274.
I have used my 9.5 countless times, from local mud riding to Pritchett Canyon, Moab. Have never had a problem, works perfect. I still use the original steel cable, no issues after approximately 50 uses. The "rope" cable does not like dirt/sunlight.
Everybody wants a cheap winch, until they need it to work![]()
Warn 9.5 ti
