Went out in the dunes today.
Had to go real easy . no bump stops, and and the drive train only has 140 miles on it.
Ran around for about 45 minutes, did all the hills,* never went over 20 mph, or over 3000 rpm.
Looks better than it did on your first go around with her :woot:
Another piece showed up today
1st time I spent the extra money and got a personalized plate
25 years later
Nice!
2, proofread and cleared by the NSA.
Tied up a few more loose ends this week.
New fuel sender (to replace the new one that came in the baskets) now the gas Guage works.
All 4 shock mounts on the axles are lowered so I've got up travel.
Rear bump stops installed
Longer shackles on the rear, lifted the rear 1/2" to level it.
Did the 500 mile change on the rear diff fluid
Added a 3rd bow to the bestop
Now more driving
A couple of updates
I got my Craigslist Ramsey winch from a couple years ago painted and mounted
Also made it to four digits on the odometer on the way to Silver Lake last night
After a couple adult beverages I was calm enough to attempt the hood decals.
The 14 year old collins brothers decals gave alot of trouble peeling the transfer paper off.
Not sure if they're in the factory location
But they are on.
Been a while since I've updated
I've been put about 4000 miles on the scrambler this summer. Having fun driving it, but I was getting tired of the bias ply tire pull on uneven roads. I wanted to try some radials..........
I found some 2 in wheel spacers on pirate and bolted on the 235's :bacon:
can you feel the difference between the tires after driving with both?
Night and day difference. The radials run way smoother, don't pull side to side on uneven road, and it will "coast" now.
But it doesn't look as cool :wave:
Maybe I should just use the 60, 14 bolt, links, and 38" Nitto's and sell the Dynatrac 44's :smokin:
Hmmmmmmm
Dirty.............I can deal with...........easy to wash
Brush scratches on the soft top.........just take it off first
skid plate and axles scares.............who's under there anyway
brush scratches on the paint.......:eek::eek:.........hmmmmm.....6 coats of clear............maybe it'll buff out................
The latest plan is put the 60, shaved 14 bolt, front coil overs and 3 link the front. leave the leaf springs in the back. keep it as short as possible with the truss on the front
axle and still have good up travel. Which looks like about 4" to 5" inches taller than now, and run some 37x12.5 tires with 5" backspace. That will put the tires about 1" out the flares.
you can see the truss in the pics of the Beast on the first page of this thread
That's quite a plan! :popcorn:
Had to park the Scram for the winter :banghead:
That means it time for the winter "upgrades"
The axles should be out of the Beast this weekend
And I dove into unknown territory....................
I bought 2 14" Radflo coilovers for the front......................... :popcorn:
And some bling for all 4 corners
And NO I don't know how to tune them :rofl:
More pics when they get here from southern California :popcorn:
This is going to be awesome!
Here are the axles out of the Beast that are going in :bacon:
Time to remove the old brackets and start fitting them in :crazy:
Chevy Dana 60 front
full truss
Yukon 5.13 gears
C&M machine bronze king pin bushings
ARB
35 spline Yukon inner and outer axles
Yukon superjoints
Balistic fab cover
WFO double ended springless high steer
behind the axle tie rod 1 3/8 o.d. .810 i.d.dom with 1 ton tie rod ends
PSC 2”x8” chrome cylinder behind the axle
Saginaw box drilled and tapped
slightly shaved
Mile marker lockouts or C&M fab drive slugs
custom caliper brackets with ¾ ton rotors and calipers so it can run 15” wheels
14 bolt rear shaved and trussed
5.13 Yukon gears
Welded Detoit, soon to be ARB
Balistic shave kit and cover
Ruffstuff bolt on caliper brackets
¾ rotors and calipers
pinion guard
1350 yoke
