IAFFCJ 81 Scrambler
Wow that is tight. I think i may have a little more room going with a full width axle and out boarded spring. But it is good to know that a 30 would work if needed.
Full width definitely helps, but it is still tight:thumbsup: Just keep the front driveshaft tube OD the same as stock, just use thicker tube:twocents:
Pulled the rear axle into the shop this weekend. Time to get that tore down and ready to go in. Going to try and get the frame stripped this week so I can get it together and have somewhere for that motor and axles to go.
One more shipment of transmission parts and I should be able to get that up to my friend for the addapter install.
I really want to get this together for nationals but I think its going to be tight on time. Well ill never know unless I give it a shot.
While I have been waiting for welds to cool on the 7 tub I started tearing into the 14 Bolt for the Scrambler. Opened it up to confirm the gearing that Truck and I tried to figure out when pulling them inside. 4.56 with an open diff. I think those will work and i am leaning towards throwing a Detroit in there to get me some traction. Pulled the shafts and figured out that it is the brakes that are keeping everything from spinning, that's a good sign. Then i tried to get the drums off. One side came off with some persuasion from a BFH but after a day and a half the other side wouldn't give up. Out came the cut off wheel as I won't be using the drums anyway. The brake pads had broken free from the backing plate and were wedged in there good, with a access hole I was able to get a pry bar in there and wiggle everything free. So I stripped the drums off the hubs and put them back on. it is astounding how much lighter it feels now but it may be in my head a little. Going to cut the spring perches and shock mounts off and inspect all the bearings. I also think I need some new seals with the amount of grease that was in the one drum. Ordered my disk brake kit I hope i can have this all cleaned up when it arrives.
Well i guess i can officially say this build is underway. The frame has been stripped of all ancillary bolt on items that will no longer be needed like those tiny axles and the scrambler tub has been hung on the rotisserie. Game on.
Go Jake, Go!
Love your setup. Are you going to blast the tub. With that setup it would go quickly.
No probly not going to blast. Dont have the blasting capabilities most of my rust removal invilves cutoff wheels and grinders.
Nice rotisserie . 👍
Very nice setup. Maybe consider a mobile blaster if there's such a person in your area. Heavy equipment people use them all the time. Would have to adjust the media though and pressures. Check around you'll probably find several. Or roll the whole thing up on a flatbed trailer and take it to them. If you look through my build you'll see everything down to the last bracket was blasted. Although it added up in the end it was absolutely the best money spent and I KNOW the metal was free of any potential rust. Plus it allows for faster and better refinishing. Throughout my build I called the sandblaster folks my new best friends. Drop it off looking like hell.. call me when it's ready. I tipped the guy doing the blasting and he was very happy to see me everytime. My stuff went to the front of the line.
Your time is money too so when you consider what an hour of your time is worth, plus the added expense of supplies to remove the paint, plus the dusty mess it makes in your workspace, and the hours of sanding and not getting into every corner thoroughly where rust hides, it's worth every penny. Do you really want to paint over 30+ year old finish? There's always the very real possibilty the newer finishes could react with the surface and cause adhesion issues. Just my :twocents:
We have a guy in our area the does wet ground glass blasting portable, did mine in my back yard.
They are correct. A blaster can get the rust at the braces and other structures under the tub. Even with that if driven in the weather give it two years and you may see the rust creap out from joints and overlapping metal. But it gives you a better chance considering all that your putting into her. Looking good.
Nice rotisserie . 👍
Yes it is. It is actually Truck's it is a huge help fixing these tubs would be a bear without it.
Well Frame has gone off to the sandblaster so i can start the welding repairs and additions to that. Parts have been ordered for most of the frame and axle work. I am sure i have forgotten something and will have to make another order. 14 Bolt has been dropped off to have the ARB installed and the transmission is out getting the adapter installed, full rebuild and valve body upgrade. While that is all out and being that it put quite a hurt on the bank account I have decided to do a mild build on the 44 that was a matched pair with the 14 bolt. This way I can get something on the trails and build the 60 i want without having to cut corners later on.
Got the 44 most of the way tore down and everything looks to be in pretty good shape so far. It will need new ball joints and axle u joints but that is to be expected on a field axle. Got tore down to trying to remove the knuckles and my back decided that was enough swinging a hammer for the day as they do not seem to want to come out very easily.
Forgot pictures before i left here is while working the spindles. They were quite ornery.
And had some presents when i got home from Brown Santa.
Full set of RE1445 springs some rear spring hangers and new shackles.
Sent from my iPad
Lots more parts arrived this morning. Traction bar kit, a bunch of spring mounting stuff, front bumper, tube fender kit, knuckles to finish up the front axle. Hoping to get the frame back Monday and start burning some welding wire.
Parts pile. Picked up some paint so i can try and start getting some parts painted up as i get them ready to mount. Now i just need the temps to get above colder than the dark side of the moon.
