First scrambler build!
ScramblerTN
Lenoir city
Tn
Hey guys. New to the site and glad to have a resource like this for info on the scrambler. I bought first scrambler last October and am in the process of a full restoration. I don't know what I've got myself into!! The jeep is a 83 model and actually in very good shape compared to others I looked at. Very very little rust and all original paint. Other than an aftermarket radio and off-road lights it is pretty much stock. Still has original spare tire mounted to roll bar. The plan is to fix any rust, coat the under side of the body and the frame, repaint with original color and decals. The body is currently off the frame and I'm looking for any advice on things that I need to take care of now. I plan on doing fuel/brake lines, cleaning tank (Polly tank). New sending unit, new shocks, header, and valve cover. Anything that can be done after body is back on frame I'm not worried about now. I'll post pictures of I can figure out how.
Also, Anyone know the correct size for fuel supply/ return and brake lines? Plan on ordering then soon.
Welcome ! The fuel supply line is 5/16" and the return is 1/4". I don't recall the brake line sizes off hand.
For the brake lines you can go to inline tube. They come pre-bent and fit well. For fuel line I went to summit racing and got a roll of 3/8" steel fuel line. I bent and flared the line for the fuel and return line. I'm probably doing a chevy 350 or amc 401 so the 3/8" line will supply plenty of fuel. Since I'm restoring, I wanted the lines as exact as possible. You can also get the clips to mount the lines from inline also.
Any idea how to post pictures from phone? Or do I have to upload from computer?
I don't have this, but it is supposed to do what you're asking:
https://tapatalk.com/
This link is for android, with reviews.
https://play.google.com/store/apps/details?id=com.quoord.tapatalkpro.activity&hl=en
Many members here use it, I have seen some negative comments recently because of changes to the app.
May not be an issue if you never used it before.
I'm sure others will have input on it for you.
Ok. Finally able to post a few pictures of the scrambler. These were taken right after I got it last October.
Much better than my start. Excellent job on the rolling table (under the tub). It beats wheels under two sawhorses with planks on top. I'm going to remember that one. Good Job.:headbang:
Thanks. I've still got a LONG way to go and it's so cold here lately it's hard to get much done. Was hopeful to have her up and going by spring but that's looking doubtful. All the rust is pretty much repaired ( which was very little) so about ready to coat frame and under side of body...then on to prepping body for paint. She's getting quite a few upgrades on engine and suspension as well.
Ok need opinions on wheels. My scrambler came with the original while wagon wheels ( including the spare). A friend of mine gave me a set of the chrome wagon wheels that the clear was pealing off and said I can have them if I wanted to clean them. I stripped the remaining clear off of one and buffed it and it looks great. Bling bling! I like both wheels..especially like that I have a matching spare on the white wheels but white wheels will need to be blasted and powder coated... But chrome will need to be waxed to keep from rusting without a clear coat
VS.
Opinions??
I like them both. What color is your Scrambler? Just FYI, the chrome will not rust as long as you keep them cleaned up. I've run mine without the clear coat for several years with no issue.
I'll agree with you. And the white wheels were standard with the SR or renegade scrambler package so if you want to say its original , go with your white ones :)
I'll admit I missed your pictures also and must say that's a great great survivor Scrambler you got there :bow: I have the same exact jeep in the same exact year and colors.
