Not as much progress this week..........................work gets in the way
tacked some gussets and stiffeners on the rear shock towers.
Tacked up and fit the shock tower connector for the front
And the UPS guy showed up again
After lots of research I went with the Holley fuel injection.
For many reasons.........
It's self learning, no more tuning.
Easy mount, 2 sensors, a throttle body, ecm, and about 3 wires.
The ecm is fully expandable. with a new harness it will bolt to a LS or other muti-port and self tune.
Out of all the forum troubles I found. All problems were solved by changing setup issues, none were the systems fault.
It controls my timing.
It has auxiliary inputs and outputs for fans, ac, and extras.
It's capable of running boost.........BLOWER.........turbo..........or supercharger
