What did you do with your Scrambler today? February 2015 Version
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
Just for Raymond...
Postal still sits in the garage radiatorless :banghead:
I drove it to work - for the first time in nearly a year...with legitimate KS tags, too!
Doors off, cause it's been in the 50s and 60s here this week ;)
Took the stupid grill off again to get to the wiring for the e-fan. Ugh. Only one is operating. Blew a fuse on the way home causing me to run hot when at stop lights. I think my power steering pulley is hitting the wired. Although it looked fine tonight. Even after re-wiring the dead fan, no dice. So I am living off of one for now. That might do in the cold, but probably won't in the warm weather. I wish I could have a mechanical fan that won't hit the radiator. Simple fix.....V8.
Can you swap on a mechanical fan or is there not enough clearance?
There is not enough clearance. I had one until last August when the fan bore a hole in the radiator starting my problems.
Got a battery charger/starter for my birthday from my wife. :)
"Ok honey, now take that charger out of the living room and I never want to see it in here again!!!!" :rotfl: :married:
But I can't get it dirty hunny and it might catch a cold out side lol...
Worked in the yard Sunday, using the HF trailer:thumbsup:
Now, out of commission, a few things to fix;
1) Starter Bendix is super weak
2) Squeaky belt, water pump front bearing shot
3) Since draining coolant, change out the coolant temp sensor
4) Address some squeaks/rattles from the full hard top
:wave:
Well I drove it to go get another one. Well it is really a TJ converted into a Scrambler style
Went to buy a used YJ soft top when I saw these. Guy said "someone stuck some cat stickers on the front...Why? I don't know." Offered him $60 so I did not feel bad. No pitting in chrome and glass is perfect. Covers were on when someone flipped the switch, but they still have clips. 1Main.jpg2Back.jpg
Went to buy a used YJ soft top when I saw these. Guy said "someone stuck some cat stickers on the front...Why? I don't know." Offered him $60 so I did not feel bad. No pitting in chrome and glass is perfect. Covers were on when someone flipped the switch, but they still have clips. View attachment 46623View attachment 46624
Go buy a powerball ticket! You are on a lucky streak!
Drove to Chattanooga for the Boat show on Saturday. First time out in a couple months. Still not running right after changing about all you can change on a 4.0... Still puzzled.:cool: May have to go to the local Jeep doc. It runs, but just not correctly... Probably take it there next week.
Wow great score... With black covers cool
Today... nothing....
On the weekend, I pulled the dead battery out of her and brought it into the house and put a trickle charger on it.
