IAFFCJ 81 Scrambler
Hey Jake thanks for not bashing the P.O....... look forward to seeing it done!
Never would i hear he is a great guy. :D. I hope i can show ya the finished product in a few months. Still optimistic but not quite as confidante
Decided to try my habd at painting with my harbor freight HVLP gun. Axle needed paint figured it would be a good place to learn. Definitely need to figure out the differant settings before i try to make something really nice but it put down paint and made the axle look a lot better.
That does look a lot better than what I saw in the back of your truck. Nice job making it look pretty.
I didn't know you got it from Chris.
Thanks John. I think I am going to become quite a fan of that little paint gun.
And I did get the Scrambler from Chris. Sorry he had to let it go but glad he did, and got to keep it in the area still.
Spent the day welding in patches in the scrambler tub. Somehow i feel like ive been here before. I am definatly ready to move on to other parts of the project. If i can keep the pace this week i should have the majority of the welding done i hope. And here are some pics for those of you who have the need.
More rust repair today. It has been a long week but i am one body mount shy of the drivers side mounts all being operational and getting ready to spin the tub around to finish up the patches for the right side up areas on the Drivers side. Wish it was going a little faster but i am making progress.
Rear body mount was completely rusted out even the top of the support so built a new one.
Also fixed the second from the rear mount.
Got the rest of the mounts freed up or drilled out and chased all the threads. Have to fix the support channel under the seat are and she should be ready to turn around and do it all again.
Started fabing up parts to repair this and ran out of time for the day.
Got the support all squared away and spun the tub around. Ran out of welding wire but got most of the drivers side cut out.
Getting closer only a few more spots to fix.
Figured yall were as sick of the patch pics as i was doing the work for them so i spared ya the last 100 or so. Tub is done all but the paint. I havent figured out what im going to do for that yet. May just hit everything with tractor paint untill i have it all together and im sure I'm done welding on the body. Then when i have more time strip it for more perminate paint.
Anyway tub is off the rotisserie and time to start the frame.
need to get the hubs back on the 60 so i can get my sawhorses back for the frame work. These showed up today so i can get everything back together
The dana 60 should be all ready to go exept for getting the steering set up.
Shoot it with epoxy, that will protect it from rust. When the time comes to paint just scuff and do any body work needed or if ready to paint then paint. Post the pics, we love seeing doing good work on their rigs and we get ideas:cool:
Yeah been thinking about epoxy. We shall see how we are doing for time once i get the frame ready so i can pull the tub back out.
Installed the Yukon hubs this morning. Will have to say im pretty impressed so far. Beafy parts and very tight tolerance. Plus they look cool. :cool:
Put the tires on the front axle so i could take it off the saw horses. Took a tape mesure to it and it works out at 83 inches wide with 11 in clearance at the pumpkin. Also realised that the metal heavy duty folding saw horses are not dana 60 strong as one had a pretty good bend in it when i got the axle off.
Took the sawhorses and all the frame parts over to the shop and set the frame up to start on. Got a little work done brfore i had to head home.
Shock towers removed, front spring hangers removed, a few stuck bolts un stucked, cut off studs from former tube steps, cut the front body mount free and bent out of the way to put on frame plates.
Forgot to take pictures but ill get some on friday for the picture lovers.
Got some frame work done today. Worked on the rust holes before i start welding the parts i have just in case this frame is not salvageable. It looks like i should be able to repair the rust holes just taking some time.
