- God's Country
- AR
You can swap 5 bolt hubs from an 82
It's not that the hubs are weak, but the bolts loosen or fall out. At the National this past weekend, I saw one broke hub due to loose bolts shearing off in the hub, and another hub that had bolts fall out![]()
Yep. I've never had any problems with the Warns or Superwinch 5 bolt hubs, but then again I've never had any come loose.
My stock hubs failed....discovered they wouldn't lock after driving into a muddy grass field to pull out a lawnmower. Not only could I not pull out the mower, but had to have someone come pull the Jeep out as well.
Talk about embarrassing.
