First scrambler build!
X100 do not put aftermarket fenders on an oem tub. Unless you absolutely have to.
X 101 I have not seen a after market body part fit right yet.
That's kinda what I figured. Think I'll try to find some oem fenders in good shape. There's an entire cj front clip for sale here locally on Craigslist...says no rust. Maybe I'll check that out
A good quality paint guy should be able to match the color. One thing that will help is to make sure he uses the exact same brand and gets it from the exact same store even if you have to get it for him. Also it will be very helpful if you know what base color the primer or sealer coat was prior to the paint being applied. A phone call to the original painter should be on your short list, and while you have him on the phone ask how many coats he applied.
My painter is going to paint all the body parts the same day. He also says he has to be sure he mixes enough paint the first time to do the entire job. It's metallic and he mixes just the right amount of Pearl also. Reducers depend a lot upon the weather conditions also, using the wrong reducer during the wrong temperature will also ruin a great paint job. Just too many variables. Climate control at this time of the year is everything in a paint booth.
Alright I'm getting ready to start working on the dash. I plan on installing a new blower motor and heater core. I've heard most of the aftermarket motors require some trimming on the firewall. I'd prefer not to cut my firewall. Can anyone tell me if there's a replacement that doesn't require cutting?
Not having much luck finding a good original windshield frame on here or locally. Has anyone had a good experience with a certain aftermarket windshield frame? This looks like I might not have a choice so if I have to go aftermarket I want a high quality piece.
I have some but haven't had a chance to get with you. Also shipping is pricey. But if you have patience hang in there a bit longer. All I can tell you about aftermarket is that the double rib look just doesn't look right on an oem resto. But that's my .02
The fenders on the RHD CJ7 are aftermarket and they did fit OK in mockup, but did require quite a bit of massaging of the holes to get it just right with the grille.
Still not perfect, but I didn't have the time to find a set of OEM fenders that weren't rusty.
I bought a Omix Windshield frame, cowl and hood for my project. The Cowl took a bit of persuading to fit but I have not mounted the hood or the windshield frame yet. The frame looks pretty good though.
Are they getting painted without fitting first or vice versa?
Well I got a little impatient last night and went ahead and ordered new fenders and a windshield frame from quadratec. I need to get this build moving and have all the body pieces painted by the end of the month if possible. We'll see how it goes. I know my paint guy will be pleased not to have to do repairs and body work
I would definitely test fit them prior to painting and adjust as necessary
I may have missed it somewhere, but I noticed your hinges and lower door mounts are already installed. They were removed before paint, correct? The factory bolted it together prior to any priming or painting resulting in bare metal creating a breading ground for rust. Awesome start. :wave:
Yep. They were installed before I came and picked it up. The guy did great work...but getting him to do any work was like pulling teeth
I don't mean to be unpopular but painting the windscreen frame and anything else for that matter before trial fit (ALL bolts in and snug, doors hung, and gaps checked) is asking for trouble. I have my fingers crossed for you :eek:
Trial fit or not when I get mine back from the painter I plan on at least two layers of masking tape on every surface that could remotely be damaged until every piece is bolted up.
Don't worry. I'll post some pictures of my trial fitting. Should be delivered Thursday so will be able to get it done this weekend then hopefully drop off at paint shop next week
