Ok.. Lets back up a bit.
As information: Most of the components like steering columns, steering gear box, brake master cylinders, etc.. on our Jeeps are "off the shelf" parts that AMC bought form GM or Ford or whoever, and used in Jeeps.
The steering box in our Jeeps from factory is a Saginaw gear box (and it uses a Saginaw pump too). They have a few mount styles, fitting styles, shapes, ratios, and sizes. A larger bore makes larger tires easier to turn. So does a higher ratio box. Our Jeeps came stock in the 80s with a 4 turn box. That means 4 turns from all the way left to all the way right. Modern cars are typically 3 to 3 1/2 turns. Some even less. That is what I mean by 4 turn ratio.
What wm69 is saying is - the box he is suggesting is an upgrade to the stock unit. I didn't know about it when I did mine or I would have tried it. Sounds like a good choice as it uses the same fittings you would have on stock 80's power steering lines. It also has the same bolt mounting pattern so it will fit stock brackets, and stock pitman arm connection to steering rods. It will also be between 3 and 3.5 turns lock to lock.
When he says variable rate, he means that the amount the tires turn, relative to how far you turn the wheel, varies from slow/small amount when you start turning the wheel to fast/larger amount as you get closer to full turn. This came about as a feature after our jeeps were made to reduce number of turns lock to lock while keeping highway speed steering adjustments slow and parking lot speed adjustments faster and easier to turn wheel.
If you have ever driven a car frm the 60s with power steering, those usually had 6 turn boxes. Your hands look like a boxer at the speed bag when you are trying to park one of those things. That gets old if you do it a lot, so better gears, variable rate, etc.. was developed.
