First scrambler build!
Checked my stock engine and intake and exhaust flanges are the same. Probably header is for aftermarket intake. Do you know if they make shims? If say you needed it to be 2 washers thick could you tack weld the washers to the header? That would be a easy fix.
On the 258 I had 17 yrs ago (sitting on racks now) I had thicker metal washers and metal shaped like a wide T. You could make up a set of washers and other pieces out of say 1/8" steel, then weld what you needed to shim onto these pieces instead of doing it on the header flange. Just need to tack so it stays put. Once it's tightened on the bolt will hold it.
Well I figured it out. I believe I used the wrong gasket. Somehow I ended up with three sets of intake/exhaust gaskets. The gasket that came with the header is a one piece gasket for both manifolds which makes the thickness even...I'm an idiot.
Well I've got another issue I need some help with. Got the windshield frame back from paint and attempted to mount it today. The windshield is an aftermarket crown and the cowl seal is also a crown. The seal seems to be much too wide. I screwed it to the bottom of the windshield in the precut holes. Any thoughts on why it's not fitting right?
Can you take a picture from the front... it looksl ike you have it 180 out of phase... the lip on the other side over the bottom of the windshield frame so it is in the front more than the rear?
I find it helps to bring all the rubber parts inside to a heated area overnight to let the rubber relax. It helps sometimes.
The front seems to fit nice and tight. I don't this seal fitting even if it was warmed up. It's probably 3/4" too wide on the inside. Could this seal possibly be for a yj?
At the risk of sounding like a idiot, did you try loosening the hinges. It may be pinching the gasket too tight.
Any of you guys had good luck with a particular brand? This one is obviously not correct so I need to look for another one. Found a NOS on eBay for $125!
That seal doesn't look right. From the side shot it looks like the defrost holes in the gasket wouldn't line up with the tub. May be a optical illusion. Do you have the original gasket. I tried one from ebay and it was too thick. Ended up cleaning and reusing the original. I see you don't even have the windshield frame bolted down (inside brackets). That would pinch it out even further.
Yeah exactly...the defrost holes are way off. Unfortunately the idiot that started my body work took off the original so I'm sure it's long gone. I did pull the windshield back far enough to bolt it to the cowl and it did push the gasket out further.
Jersey may be able to help with a used gasket. He's helped me a time or two.
I hope you get this problem solved because I'm going to need all new rubber real soon.
The main issue I see with the aftermarket seals is the ill fitting look from the front , not having nice curve/curl against the outer frame. What I am seeing on yours is something way wrong and length on the back side.
Hate to say it but maybe return it ? Down time is another ridiculous issue to deal with on poor quality aftermarket parts :(
It's really not a big issue as far as time goes. It's got to be right. Unfortunately I bought the seal over a year ago and can't find the box so probably won't be able to do a return
I'm ready to order all new rubber for my own Scrambler build. Can you guys help me out with the BEST place to buy with the best fit? Is OEM still available any where?
