On the way back from M&G, my engine started randomly cutting out at 2000 RPM. I could be cruising along just fine, and then it was like the ignition just shut off. So I was leery of driving it much this summer until I had that fixed. I did order an MTX-AL wide-band O2 sensor and gauge by Innovate Motorsports after finding an open-box deal on Amazon for like $100 off.
But I still haven't installed it yet.
The only other thing I did was take it to a Jeep event at a dealership just down the street, just for a few more glamour shots.
The engine was still cutting out on me though.
In spite of that, I did want to take it wheeling, but I'd removed my OEM hitch in anticipation of making that Body Armor bumper fit. That obviously didn't happen. Rather than put the OEM hitch back on, I wanted to at least slam a receiver to give me some practical usage, and I figured I could fab something pretty easily using a random receiver. Lucky me, I found a guy with a tow company that scrapped a truck that was loaded with hitches. He'd been selling them off for $20 per hitch for a couple years. I decided I could bend the frame horns out, and drill it to bolt to the CJ cross member, and have something to work with. Granted, this isn't necessarily the ideal solution, and there's a chance that the center bolts would just pull through in the event of a hard pull, but I'm confident that the 1/4" plate on the sides would prevent any catastrophe, and this is still just a temporary measure. Oh, I also finally got my frame reinforcements installed too:
With the paint dry in the morning, I bolted it on and went wheeling. We already had some freezing temps and the puddles were frozen. The one at the trailhead was shockingly deep; at least 33". For a heartbeat I was afraid I was going to need to get out and lock my hubs, but the Boggers just chugged through and I crawled out. As I was catching up to the group though (I was late since I was putting the hitch on), much to my dismay, I got effectively high centered on an ice pile! The Boggers just couldn't get enough traction to go forward, and when I tried to back up to go again, my front tires couldn't get back over the ice either! I was sitting here, not even really stuck, but having to winch.
And a couple more shots from the day:
The engine didn't cut out at all on the drive there, but when I was breaking trail for the group and needed a little more power to chunk the ice, it was cutting out--usually at incredibly inconvenient times. Even with that, I still put it into the deepest holes and it crawled out. Except for two times when JUST the rear axle fell through the ice (apparently I'm heavier in the back with the extra fuel tank and a load of gear) and the Boggers couldn't get the traction to get the rear back on top, so I still got strapped twice.
I'm going to order a new EPROM for my ECU to see if that solves the problem. In watching it with the laptop, when it cuts out, the idle-set speed jumps from my setting of 700 to 1500, all on its own. But when the engine's actual speed drops back to 1500, the ECU will drop the setting back to 700 (without cutting the ignition). None of this makes any sense to me, and the Holley techs weren't any help ("check all your wires to make sure nothing is frayed"). But either way I think it's a hardware problem in the ECU. I just hope I don't need a new ECU since they've been out of production for 15 years.
