Thanks guys. I appreciate it. Been through it a number of times. Never easy.
Anyone know the easy way to loosen the nut on the axle that is in my yard? Even with things jammed in the ends of the axles, the whole thing keeps moving on me when I try to turn the 1 1/8 nut holding the yoke on. Grrr
I used an 18" or 24" pipe wrench on the flat sides of the yoke to get them off. Impact wrench helps too.
The pipe wrench is used to hold the yoke from turning while unscrewing the nut.
Put a good sized cheater bar on your breaker bar also. That nut is torqued to somewhere around 200 foot pounds IIRC.Ah. Gotcha. I have the pipe wrench. I will try that. Thanks a lot.
Heat the nut too Dain
Dain looks like we both have the same goal, do anything to avoid the electrical mess.
