My De-Rustification Project
Sorry to hear about the pup. My Jammer is 12 1/2 yrs old and I thought we were going to loose her last summer. I feel for you because I'm going to be a mess when our time comes.
So thanks to Dustin, Jake and James for ferrying the new to me doors to Ashburn.
. Test fit was really good on that side. I will clean them up a bit and they will be ready for next winter.
Played a little with the electronics. No change. Will do more when the family is out tomorrow. James almost has me convinced to take the dash out and start from scratch with a new inside harness. I am close to it. I think I will focus on the brake bleeder valves tomorrow. Gotta get those off the front brakes.
So started to tackle the retaining bolts broken off in the yoke of the dana 30. Broke a few bits off in the bolts. I am going to pull off the yoke and replace it with the one on the axles I am replacing and have in my back yard. I am done with messing with that. Now to find out how easy it is to remove that yoke.
Anyone know the easy way to loosen the nut on the axle that is in my yard? Even with things jammed in the ends of the axles, the whole thing keeps moving on me when I try to turn the 1 1/8 nut holding the yoke on. Grrr
And to do something positive today, I ground down the frame tie-ins and painted them along with a bunch of touch ups to the frame. Avoiding the electricals. Though I really do think that I have an issue with the connection between the harnesses at the firewall. I need to take that fuse box off of the inside of the firewall and take a look at it. I am thinking that some wires are not making good connections.
I used an 18" or 24" pipe wrench on the flat sides of the yoke to get them off. Impact wrench helps too.
The pipe wrench is used to hold the yoke from turning while unscrewing the nut.
Ah. Gotcha. I have the pipe wrench. I will try that. Thanks a lot.
Put a good sized cheater bar on your breaker bar also. That nut is torqued to somewhere around 200 foot pounds IIRC.
Thanks Jake. I figured I would need my 8 ft cheater bar. I will use that along with the pipe wrench.
This project is definitely more that I planned. Ugh.
Still avoiding the electrical mess, I painted the second coat on my flat metal holding the rollbar to the bed. I will have the frame tied in at a later date. I also put a coat of paint on the hinges that will be replacing the chrome ones. I will be glad to be rid of them. I mounted the lower hinges as they had been painted this past summer. I had to reuse the chrome bolts. But those will get painted. Dumb fiberglass body was too thick to use the stock torx screws.
Still avoiding the electricals. So I bolted down the rollbar tonight and attached the seat belts. I also put a second coat of paint on the windshield hinges. And tested the chrome bolts to see if they will come off nicely. All but one broke free. The last one wants to strip. I only tried the driver side. And I realize that the stock hinges I am putting on need different bolts anyway, which is good since I did not want to use the chrome round head bolts. I will get recessed ones to replace them.
Dain looks like we both have the same goal, do anything to avoid the electrical mess.
