- Houston
- TX
Tried something else today. I unplugged the VSS and took a test run just to see and the truck acts the same except that the speedo doesn't work. Plug the VSS back in and the only difference is the speedo works. Appears to me that the truck is in Limp mode either way, if I put it in drive I believe it is shifting to second gear, If I manually shift I can go from 1st gear to 2nd gear.
The CEL is still not coming on and I am still not seeing any codes on my scanner. It looks to me like I am having a communications problem somewhere. I'm not beyond bringing it to someone who has the proper equipment to check all the systems out properly.
I used Advanced Adapters 50-0405E to adapt my NP241 to my 4L60E. (and then I put a D300 with 4:1 behind it!)
VSS set at 0.010-0.012" spacing.
Possible you still have VATS enabled?
