- Claflin
- KS
Bolts to the frame and crossmember in the original locations. Also has a spot to drill an optional 3rd bolt through the crossmember for added strength.
Sent via smoke signal
Can I buy a magnetic filter at any auto store?
Make sure the new gearbox is centered when you connect to the steering shaft (if the rotation range is 3.5 turns then you want to have it set at 1.75 turns). This makes sure you have full turning radius and your steering wheel will be centered while driving straight.
Once you have everything together, add fluid and let it set for a while (gravity will help displace some of the air trapped in the gearbox and lines. Then you want to lift the front wheels off the ground and turn the steering from side to side multiple times to help force more air out (do this without the engine running). Keep adding fluid as needed until you get as much air out as you can. Then you can start the engine and do the same thing while the pump is running (keep adding fluid as needed). When you first run the pump it's common to get bubbles/foam in the fluid so be careful you don't burn up the pump.
