Power Steering fluid Leak
Bolts to the frame and crossmember in the original locations. Also has a spot to drill an optional 3rd bolt through the crossmember for added strength.
Sent via smoke signal
H1 box uses the same mounting points as a stock box..
Sent from my SM-N910P
Thanks for the input fellas - I will check it out today.
Morning:
What is this on top of the H1 steering box? It has a thread on the outside.
Thanks.
That is to adjust the tension on the gears. Don't mess with it.
Hello:
I just got the M.O.R.E steering brace so I am installing the new H1 steering box and Bergeson shaft. Are there any secrets to the installation of the steering box and adding the power steering fluid?
Should I fill the steering box with fluid prior to screwing the fluid lines back onto the steering box? I am kicking myself because I cannot locate the instructions that came with the box.
As always I am grateful for the advice.
Make sure the new gearbox is centered when you connect to the steering shaft (if the rotation range is 3.5 turns then you want to have it set at 1.75 turns). This makes sure you have full turning radius and your steering wheel will be centered while driving straight.
Once you have everything together, add fluid and let it set for a while (gravity will help displace some of the air trapped in the gearbox and lines. Then you want to lift the front wheels off the ground and turn the steering from side to side multiple times to help force more air out (do this without the engine running). Keep adding fluid as needed until you get as much air out as you can. Then you can start the engine and do the same thing while the pump is running (keep adding fluid as needed). When you first run the pump it's common to get bubbles/foam in the fluid so be careful you don't burn up the pump.
One other thing I'd recommend; If you don't already have one, this would be a good time to add a magnetic filter to your return line. Great for picking up any metal particles that may have been introduced during assembly. Helps extend the life of the whole system.
Am I doing this with the steering fluid lines attached to the steering box? (just filling from the reservoir)
Which line is the return line?
Thanks.
Yes all lines are attached while doing this. Return line is the line attached to the back of the pump with just a hose clamp.
Can I buy a magnetic filter at any auto store?
I got this Magna X 2210 at Pep Boys for $15, but there are other options;
Sir:
I am installing the new gear box and have been thinking about something you said in the post (make sure the gear box is straight) well the spine coming from the steering column is facing right (if you are looking at it from the front of the Jeep) I have attached a few photos. Can you tell if the steering box looks like it is sitting / facing the right way please.
I do not want to go any further if it does not look right. I never thought to take a photo from this angle prior to taking the box out
Thank You,
Wayne.
Wayne,
I just went out and checked mine, it looks just like yours. The bolt holes really only allow it to mount one way.
I believe Spieg was advising that you make sure the input shaft to the box is centered in its range of travel, between full lock counterclockwise to full lock clockwise, before connecting the shaft between the box and the steering column (after you make sure the steering wheel is positioned properly).
HTH
Too dark for pics.
Thank you very much:
Not sure how to put this, but are you saying physically turn the input shaft by hand clockwise and anti clockwise and I will be able find the middle/center?
Example.. Turn the shaft all the way to the right as far as it goes and then turn it to the left, if it takes 6 turns to the left then go back 3 turns and then the box is centered?
I believe that is what your saying..
That is cool, thank you to you & FLCJ8 for bringing that to my attention.
Wayne.
