- Gonzales
- La
Yes it does. Even the Hummer is smaller than the Avalanche. The H1 is not as long and not as high but it is about 11 inches wider than the Avalanche.The scrambler looks sooooo small behind that Avalanche.
Sent from my iPad
Sent from my iPad
That's the biggest problem with these coolers here in Louisiana where the RH rarely gets below 85%.We design and build these at my company, the concept is pretty simple, if you locate the inlet air condition on a psych chart (say 90 degrees and 50% RH) and follow it strait up the wet bulb line 80-95% of the distance to saturation, that will be the leaving temp. They are absolutely stellar in dry climates (Colorado)....less so in extremely humid
CB, are you trying to piss me off? LMAOIt is 60 degrees in July right now in NH watch out for cats and dogs falling from the sky
I'll just quit complaining.You?
Sent from my SM-G920V
4:10 Gears. Good news and Bad news.
Good news is they are installed and working properly so far. The performance is so much better but maybe not as good as I was expecting but is probably exactly what I needed for my type of driving. It still won't exactly smoke the tires the way I hoped but I did knock almost 3 seconds off the 0-60 speed time. 11 seconds doesn't sound fast but it's not all that bad.
Bad news is my installer really sucked. It took him 6 days to do what he said he would do in two. Then he said that when he took a rear brake drum off it was all messed up inside. So all I said was I had great brakes and made it to your shop just fine. What I think happened was he completed the work and took it for a test drive and that's when something came loose in the rear drum. Come to find out that two of his three mechanics quit him last week. I told him to leave the brakes alone that I would fix them myself. What I really want to do was punch the lying SOB in the mouth. But I didn't, I just paid the man and left forever.
I guess this is a good time to think about a rear disc brake conversion.
We have a guy down here, all he does is gears and drive shafts, been doing the same thing for over 40 years. Great work, great prices, no one I know, even with the crazy kamakazi buggies, has ever had problems with his work. He does a bunch of stuff on race cars and high HP street rods, too
Next time you need gears or drive shafts, give me a shoutWe have a guy down here, all he does is gears and drive shafts, been doing the same thing for over 40 years. Great work, great prices, no one I know, even with the crazy kamakazi buggies, has ever had problems with his work. He does a bunch of stuff on race cars and high HP street rods, too
Scrambler looks great![]()
