A re-introduction...
pookie
Knoxville
TN
So apparently in 2009 I was looking for a CJ-8 and found this site: https://www.cj-8.com/forum/showthread.php?23244-Newb-CJ-8-Questions-kinda-long
And then life got in the way. Two kids, and 3 Jeeps later (JK, TJ, TJ) I'm back looking at CJ-7s and CJ-8s. I was involved in a wreck on Sept. 2, (thankfully no injuries, just body damage to all vehicles involved) and my last TJ was declared a total loss. :(
I do have a couple different questions now since kiddos are involved.
1. Has anyone found a good method for mounting 3 point belts in a CJ-8? Would it help to mount the belts if a "family cage" was added? Similar to this http://extremecustomparts.com/i-504...-full-family-roll-cage-kit-cj8-scrambler.html although on that one it would need an extra bar closer to the rear seat.
2. Is anyone using this seat? http://www.quadratec.com/products/24277_10XX_PG.htm And if so how do you like it?
I'm in Knoxville, and found a couple somewhat close and I am working with the sellers to see when I can look at them. Wish me luck.
You should absolutely do a full cage to add three point belts to handle both the belts and rollover protection. I kick myself for waiting as long as I did to do my full cage, thankfully I never needed it but I should have done it sooner.
No experience with that specific kit, but FWIW, it needs a lot of additional bars for triangulation. It looks like a good base, but I'd either have someone with significant cage building experience add to it or study a few of the cages here to help. I mounted rear LJ seat belts in mine off of the C-pillars (back corners) that have worked great.
I have the Trailmax Pro front seats in mine and I NEED to go to the rear seat you mentioned to get the headrests. I have a CJ fold and tumble without headrests and this is another one I need to get done sooner than later :banghead: (and that's an appropriate smilie :eek:) The key is knowing it will fit between the wheelwells, so you have that covered there.
On the purchase, do not rush into a Jeep just because it's close and they're "hard to find." I'm assuming/hoping that this isn't a primary vehicle for you (if it is, there's another discussion to have about the LJs) and you don't want to compromise just to get back into a Jeep. Probably much easier said than done, but worth a mention as you start looking.
You're already more than halfway there simply by getting back on here :cheers:
Good luck!
The cage does look like a base, as BW said it needs additions, they sell them but by the time you buy them, you may be able to find a local place make one for the same price or better especially if you have to have that kit installed.
Sent from my SM-J320P
Bigwalton- my wife and smaller kiddo where in the TJ during the accident. Like I said we are all fine and healthy, so the Jeep did it's job. But it reinforced that our older kiddo's head would have been above the back of the TJ and they may have been injured or suffered some sort of whiplash. I told my wife if we fixed the TJ or got another Jeep a different seat would be going in for the kids. I looked at the later TJ seat 04+ and while it has the LATCH system for car seats, it does not have higher headrests. Then I found the seat I posted.
BW and barrys- thanks for the tips on the cage. I was trying to get a ballpark of what things I would already be adding if I purchase a CJ, rear seat, seatbelts front and rear, and better cage are the first. I'll worry about mods for the everything else later.
My primary commute vehicle now is a motorcycle. :rolleyes: The CJ will be my weekend/take the family around/top off/camping hunting/and one our two snow trip vehicle. I also have a 1942 Willys MBT that it needs to be able to haul, since none of my camping stuff fit in the TJ. But since the trailer weighs so little it can be pulled by pretty much anything.
I looked at LJs as well but I don't lust after those. Also the ones I see seem to have high mileage, and so so many automatics. I did consider them for the airbags, and they are still on the list, just not my #1 choice.
This one has 3 points all the way around. It's local so if you find one and like this setup I can ask him how he did his and how he likes it.
I've been out of town and just got back. I may see him next Sunday and/or I will try to get in touch with him and get some information.
I know this doesn't help much but he says it is a custom built by a local shop out of 2 CJ7 rollbars. If I can find out any details on it that will help you guys I'll post up.
