- Biloxi
- MS
My second '78 CJ-7 came with a '74 304 swapped in. The engine was stock, except for stupid out of frame headers. I installed stock manifolds with a Y pipe.
I drove this Jeep for quite a few years, including too many to remember back and forth trips from Biloxi, MS, to Starkville, MS (300 miles each way), while I was in college. It was very reliable, good power, 17mpg (33" tires, 3.54 gears, T-18 4 speed, Dana 20, 65mph on back roads/highways).
I, and the previous owner, plus a cousin of mine, could not keep T-150's alive for very long behind the 304's
That is the main reason I swapped in the T-18. The T-150 broke after 3 months of ownership, and I broke (x3) T150's behind stock 258's. I think T-150s are almost as weak as T5's
Anyway, I like the 304. After I graduated college, 2005, I had the 304 rebuilt and modified by an engine builder - bored 30 over, crank turned, some type of RV cam, Edelbrock intake, Edelbrock shorty headers, 600cfm Holley truck Avenger, DUI HEI distributer, some type of head work, etc. It made a bunch more power, but the MPG went way down. I sold the whole Jeep to a buddy of mine when I was building my red Scrambler. It is still running great to this day.
After having the a "stock" 304 and a "modified" 304, I actually liked the 304 more when it was stock
They make decent power, quiet with stock manifolds/single exhaust, excellent Motorcraft 2 barrel carb, reliable/easy to work on/cheap Motorcraft ignitions, decent MPG. I never had any problems with my stock 304, leaks, carbs, overheating, etc. It always started up, ran fine.
IMO, they do make a bit more power then a carb equipped 258, noticeable at highway speeds, just feel more responsive overall. That being said, I like my MPI equipped 258 over the 304. The 304 might make a little bit more power, but it does not have the responsiveness, easy cold starting, reliability of my MPI equipped 258
I still like the 304's, if I had a Jeep that came with one I would leave it installed, but I wouldn't swap out a good 258 for a 304
They make decent power, quiet with stock manifolds/single exhaust, excellent Motorcraft 2 barrel carb, reliable/easy to work on/cheap Motorcraft ignitions, decent MPG. I never had any problems with my stock 304, leaks, carbs, overheating, etc. It always started up, ran fine.IMO, they do make a bit more power then a carb equipped 258, noticeable at highway speeds, just feel more responsive overall. That being said, I like my MPI equipped 258 over the 304. The 304 might make a little bit more power, but it does not have the responsiveness, easy cold starting, reliability of my MPI equipped 258
The 304/33" tire combo, lots of miles and off road usage, really killed them fast
