Any love for the 304 V8
My second '78 CJ-7 came with a '74 304 swapped in. The engine was stock, except for stupid out of frame headers. I installed stock manifolds with a Y pipe.
I drove this Jeep for quite a few years, including too many to remember back and forth trips from Biloxi, MS, to Starkville, MS (300 miles each way), while I was in college. It was very reliable, good power, 17mpg (33" tires, 3.54 gears, T-18 4 speed, Dana 20, 65mph on back roads/highways).
I, and the previous owner, plus a cousin of mine, could not keep T-150's alive for very long behind the 304's :twocents: That is the main reason I swapped in the T-18. The T-150 broke after 3 months of ownership, and I broke (x3) T150's behind stock 258's. I think T-150s are almost as weak as T5's :twocents:
Anyway, I like the 304. After I graduated college, 2005, I had the 304 rebuilt and modified by an engine builder - bored 30 over, crank turned, some type of RV cam, Edelbrock intake, Edelbrock shorty headers, 600cfm Holley truck Avenger, DUI HEI distributer, some type of head work, etc. It made a bunch more power, but the MPG went way down. I sold the whole Jeep to a buddy of mine when I was building my red Scrambler. It is still running great to this day.
After having the a "stock" 304 and a "modified" 304, I actually liked the 304 more when it was stock :twocents: They make decent power, quiet with stock manifolds/single exhaust, excellent Motorcraft 2 barrel carb, reliable/easy to work on/cheap Motorcraft ignitions, decent MPG. I never had any problems with my stock 304, leaks, carbs, overheating, etc. It always started up, ran fine.
IMO, they do make a bit more power then a carb equipped 258, noticeable at highway speeds, just feel more responsive overall. That being said, I like my MPI equipped 258 over the 304. The 304 might make a little bit more power, but it does not have the responsiveness, easy cold starting, reliability of my MPI equipped 258 :twocents:
I still like the 304's, if I had a Jeep that came with one I would leave it installed, but I wouldn't swap out a good 258 for a 304 :twocents:
I had one in my 74 CJ5, I loved it, wish I had it in my scrambler, i might decide to keep it if I did. Best tank was just above 19mpg, generally over th e28 years I had it I got 15 mpg or so all around, a skosch better than my 258, 4.0 head, MOPAr EFI Scrambler
Thanks for sharing your expierences with the 304s and the comparisons. I'm liking them even more. I've got a couple T-150 with TCs from 2 77 CJ5s. Sounds like I'd be better off not using them. It's amazing that the 258s and even the 304s get better mileage than the YJs I've had with the 4 cylinder engines. All info appreciated.
Interesting... we have 2 T-150's and aside from a synchro going between 2 and 3 in one that has never had a rebuild, no issues... How are you driving them things!?!?!?!?
LOL :rotfl:
Well, my first car at 15 was my '78 CJ-7, so that might explain some of it :evil:
But in all seriousness, I was not that "hard" on them, no full throttle clutch drops or anything. I did put a bunch of miles on them, drove to school 5 days a week, afterschool job 6-7 nights a week, two jobs in the summer, a bunch of mud/trail riding, and that was all behind a 258, mostly 31" tire use. Once I stepped up to 33's, I would get less mileage out of the T150's :shrug: The 304/33" tire combo, lots of miles and off road usage, really killed them fast :shrug:
I stayed all AMC and went the 360 route from the get go in my CJ-8. Had a friend with the 304 in a CJ-5 back in the day but never really new enough back then. My 360 is stock on the bottom end, has Edelbrock 600 carb, modified rpm manifold, RV cam, slightly shaved heads, Doug Thorley Tri-y inside frame headers, through a 2.5" mandrel SS exhaust and Borla cans. It has all kinds of power with the improved exhaust flow but uses a bit of gas driving around town. I think mainly due to the lower 4:11 gears and 33's. I may put a set of 3:73's in the future but I really don't highway it. I love the exhaust note although it did take a while to get used to. I would say go ahead with the 304 and put some new technology into it, maybe even a forged bottom end. Electronic ignition, better plugs and wires, and maybe a good porting job and some head work to let it breath. Then make sure you get a good carb and tune it properly.
uploadfromtaptalk1362860086590.jpguploadfromtaptalk1362860064814.jpgI have had 2 304's
1. in a 1981 cj7, 3 speed auto, dana 300, 4.10 gears. 33" tires. was built up. the auto robbed the power, in my opinion.
2. in a 1985 cj7, 5 speed, dana 300, 4.10 gears, 33" tires. was blue printed and balanced. It was built. It went.
