Jeeps, Trades, Camaradarie... and a padded Grab Bar!
Steve. Did you try to make the grab handles for your doors, or are you going with the original ones offered?
I have not finished them yet, hopefully this weekend.
Getting the conduit bent just right, and pinching/bending the ends is not working as easily as I'd hoped....
I'll keep trying though, I'm not going to use originals.
10-4
Put me in line for a grab bar once you get into production!
Jim, I completely missed this post! I apologize. :bow:
I do think I'll take you up that tan door pull, just in case I can't make the conduit work.
I'll PM my info, so you can figure a shipping cost. Thank you! :thumbsup:
You pay shipping
I have reversed my position, 180 degrees!
I fk'd around with conduit all weekend, and couldn't get it to bend the way I wanted it! This project will require an actual tubing bender (with the correct dies), which I do not have... and I'm not going to buy it just to make door pulls.
Jim's Chop Shop has graciously offered to send me a factory door pull to replace my broken one, and I whole-heartedly accept! :thumbsup:
Thank you, Kim Dawson, for offering to leather-wrap my home-made door pulls... but it's just not in the cards for now.
Take it easy! :cheers:
My local library has a laser cutter and cnc mill free to use. The laser says it will cut leather. If this is something Kim makes a pattern, we may be able to cut quick and accurate!!!
Also has an air knife vinyl cutter
That is a fantastic local library!
Not sure how I missed this, but just wanted to comment on Kim's work. That bar looks GREAT.
I gotta check my library out
..wow!
Sent from my SM-J320P
That's a whole new meaning for a library. Thumbs up for Kansas! I make leather parts for cars in the early 1900s out of harness leather. Some of them I have a die made that is like a knife the shape of the part. I put the die in my press on top of the leather and work the hydraulic jack until it punches out the part. A production shop that cuts out lots of parts will have a clicker machine. The clicker has a large bed and the upper plate comes down under power like a power brake and . . . click . . . your part is stamped out. For now, I'm using scissors. I've sent off for some samples of leather and am trying to locate some original materials to match before I order leather in the different colors. BrooklynZ28 is sending me a slate blue grab bar for reference. I took apart my nutmeg grab bar. I don't have any honey or garnet parts to match so if someone has a torn up seat they can cut a spot with accurate color and send it that would help. If that doesn't happen, I have Napa making up those colors and I'll match the paint.
